Page 9 of 21 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 204
Thread: Paper and pencil
  1. #81
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Quote Originally Posted by Meelobee
    I've put this in my skin:
    /, A, x, y, w, h, color;RGB
    A01,45,70,710,477,0
    and it still won't show
    I'm not 100% sure why, but I have this in my skin as well:
    A01,0,84,800,516,000
    /, C, x, y, w, h
    C01,0,84,800,516
    Maybe the Clip region is required?
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  2. #82
    May 2005
    Thanks Viscouse adding the clip region worked
  3. #83
    Raw Wave lostreception's Avatar
    NY
    SWF Problem Solved
    if you want to embed as solely a swf you can now draw onto the background
    the background is still transparent so you will need to have the background color of you skin .jpg set to the color you want in the background
    this may be useful to some for skinning purposes for example see below
    only draw back is you cant load draw ontop of gps or any other active text in rr
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  4. #84
    NY
    I forgot you will need this modified swf if you wish to do this as well
    Attached Files Attached Files
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  5. #85
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by lostreception
    sweet, this works out good.
    I must say though, is there anyway to bring back the old style menu on the bottom(post #39)? Right now its takeing up too much space. How many people are working on this? Every download seems like it has a different interface/layout, but with a different quirk. The reason i like it on the bottom is that it scales much better than on the side.
    beer replenishment fund
    mp3car live search
  6. #86
    Variable Bitrate Erwin's Avatar
    Mar 2005
    SWF Problem Solved
    THNX! It works fine now.
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
  7. #87
    NY
    Quote Originally Posted by liquid_smoke
    both myself and chuck are working on it
    i can move the buttons if you like
    are you looking to bundle it with the lsx skin
    i can move the buttons for you give me the dimensions you want
    (it might take a few days tho, im focusing on the vehicle maintenence program now)
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  8. #88
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    YAY! It's working now, sort of. When I save #1 and go to #2 and save, #1 gets erased when I go back to it. Where are the drawings saved and what are their filenames supposed to be?
    I also agree that the buttons take up a bit too much space. Left side buttons are ok for me but they could be squeezed over a bit and eliminate the blank dead space on the sides of them.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  9. #89
    Aug 2003
    Chicago
    sweet, that sounds awesome. I do want to bundle it. I dont have any pixel dimension requirements. The way it looks in post 39 is fine with me.
    mp3car live search
  10. #90
    NY
    Quote Originally Posted by wysocki
    if you wish to find the drawings they are not pixel based they are saved as vectorbased instuction sets telling flash what to draw
    the saving format is userdrawing+n.sol
    save in position one and search for userdrawing1.sol
    .sol is a shared object in flash kind of like an internet cookie
    the default location of the file will be C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\localhost\*file path where you put the file*
    Hope this helps
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
