Results 1 to 10 of 11
Thread: Skippy any way to use netdetect to auto download weather info for RR?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Any ideas?
    Sound Stage
    Eclipse|MTX|Infinity
    Nov 2007
    RR.. Needs this bad. Alot of us have wifi at home and at work. I would use RR more if that data was loaded on every wifi connect. Heck I would donate $100 to anyone that makes a plugin to auto update.
    1999 Black Camaro Z28
    Lilliput 701-Athlon 64 2800-512ddr-40gb-Earthmate GPS-iNav-RoadRunner-Wifi
    Installed.. Finally
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    interesting , with wifi_man plugin i think is possible.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by EL CAMINO View Post
    Go get them 100 bucks El C..you can come up with something!
    Nov 2007
    Not just weather, gas prices too
    Installed.. Finally
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by dbrown View Post
    careful what you say.. i'm a whore like that lol. If you're serious i'll crack open the source monday.
    Live mp3Car Facebook Chat
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    this is not that hard. just go find that program that creates a file everytime that an internet connection is found. then do
    "EXISTS;file.txt" and have it execute something. shouldnt be that hard. ill try tomorrow.
    EDIT: autonetdetect? is this not already done?
    Chucks Online detecter - AutoNetDetect
    ^^^^download that, run chucksonline.exe at RR startup, and then put in exectbl.ini:
    Code:
    "ONLINEPINGON","RELOADWEATHER||UPDATEgpsGAScommand"
    ill split the hundred with chuck and whoever else made it. thanks. haha
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    You could run this from NetDetect,should do the trick.
    Attached Files Attached Files
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Nov 2007
    Quote Originally Posted by tundra2000 View Post
    Code:
    Any luck on this? I want to start my car and all the online stuff update. Simple as that.
    Installed.. Finally
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    I have something like this working. It checks for an internet connection every so often (whenever you want)...then it will run a command. The command can be in either RR or external commandline (3 of each). Then it can be configured to execute that command every so often(3 of each). Also disconect commands and an online indicator. This little project started because ping doesn't work accurately for me(half of what I connect to via wifi blocks ping even when connected). So, this script doesn't use ping, it checks the size of an online file. I don't know if I'd call it finished yet, but I've ran it a couple of weeks at a time checking every 4 seconds, reloading weather every 250 checks If I ever get it done I'll post the script in the plugins.
    current ini: (some of the variables need to be changed to make more sense)
    [online status]
    SETVAR=ONLINESTATUS
    URL=http://image.weather.com/web/blank.gif
    RUNAPPCONNECT1=
    RUNAPPCONNECT2=
    RUNAPPCONNECT3=
    RRCMDCONNECT1=RELOADWEATHER
    RRCMDCONNECT2=
    RRCMDCONNECT3=
    RUNONCE1=
    RUNONCE2=
    RUNONCE3=
    RUNONCERR1=
    RUNONCERR2=
    RUNONCERR3=
    RUNAPPDISCONNECT1=
    RUNAPPDISCONNECT2=
    RUNAPPDISCONNECT3=
    RRCMDDISCONNECT1=
    RRCMDDISCONNECT2=
    RRCMDDISCONNECT3=
    RUNDISCONNECTONCE1=
    RUNDISCONNECTONCE2=
    RUNDISCONNECTONCE3=
    RUNDISCONNECTONCERR1=
    RUNDISCONNECTONCERR2=
    RUNDISCONNECTONCERR3=
    SLEEPTIME=4000
    EXECUTEEVERY=250
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. Weather info based on GPS location?
    By jzkbbi in forum Road Runner
    Last Post: 11-03-2005, 12:53 PM
  2. Weather info work only in USA?
    By slimmegane in forum Road Runner
    Last Post: 09-29-2005, 08:18 AM
  3. Feature Request: auto Weather dl option
    By ryguy in forum Centrafuse
    Last Post: 06-15-2005, 11:41 PM
  4. Suggestion: Auto Zip Code for Weather
    By Mbai2 in forum Centrafuse
    Last Post: 04-05-2005, 02:57 PM
  5. XP Lite Info & Download !! (LitePC)
    By CivicDisturbance in forum Software & Software Development
    Last Post: 11-26-2003, 04:24 PM
