Results 1 to 10 of 17
Thread: MC2.0 skin and CDRIp
    Dec 2005
    Can anyone help with this, I have searched and think I have tried most options but always seem to get stuck.
    I can launch CDRIp from the MC2.0 skin by using the following command;
    &button14=CDRip@LOAD;CDRIp.skin;RRCDRIp;C:\Prog ram Files\Road Runner\CDRIp\CDRIp.exe&
    Everything works the cd drive is recognised and I can rip music all day long if I want.
    The problem comes when I try to quit the screen and return to the main menu, the commands I have tried and results are listed below,
    Command "ESC"
    Result skin quits, main menu doesn't load although Road Runner is still open in the task manager
    Command "EXIT"
    Result Same as ESC
    Command "EXITPLUGIN"
    Result Does nothing, CDRIp skin won't quit, Road Runner still open in task manager
    Command "LOAD;menu.skin"
    Result Same as EXITPLUGIN
    Command "AUDIO" (same as some commands in other skins)
    Command "LOAD;menu.skin;C:\Program Files\Road Runner\rr.exe"
    Result Loads menu.skin but does not load main.swf, CDRIp does not quit and buttons don't work properly
    Command "LOAD;menu.skin;Road Runner;C:\Program Files\Road Runner\rr.exe"
    Result Same as LOAD;menu.skin;C:\Program Files\Road Runner\rr.exe
    I have tried everything I can think of and CDRIp works with another skin using ESC as the command on the back button. If someone can help or suggest something, please let me know
    FLAC J187's Avatar
    Nov 2004
    Boston
    do these exist in your ExecTBL.ini?
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Dec 2005
    yeah they do, and everything works in the bmv2 skin
    FLAC J187's Avatar
    Nov 2004
    Boston
    When you use ExitPlugin, you are saying that pressing the button literally has no effect? The screen just stays at CDRIP?
    Please help.
    Dec 2005
    Yeah, cdrip stays open, rr is open in the task manager and cdrip is still fully functional
    FLAC J187's Avatar
    Nov 2004
    Boston
    Now, I don't think MC2.0 has a cdrip skin, is this something you made yourself? Can you post your skin?
    Please help.
    Dec 2005
    Release - MC2.0 Skin
    I have tried putting the cdrip.skin and jpgs from the BMV2 skin and the same things happen
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Hi,
    I also had some problems implementing CDRip in the MC2.0 skin. Here is my thread: CDRip displays current playlist i.s.o. CD content
    I use the command:
    &button14=My CDRip@LOAD;CDRIp.skin&
    The CDRip skin loads but my promblem is that CDRip does not find the correct CD path. It always shows the current (MP3) playlist.
    After reading your topic I tried the command:
    With this command CDRip does display the correct (CD) path. Now I have almost the same problem as you. When I close CDRip RR (visualy) dissapears while the music keeps on playing. Using the task manager it seemed that RR was still active but was not visible anymore. Killing the task was the only option.
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
    FLAC J187's Avatar
    Nov 2004
    Boston
    Here, use this command instead
    &button14=CDRip@LOAD;CDRIp.skin;PLUGIN;RRCDRip;C:\ Program Files\Road Runner\CDRip\CDRip.exe&
    Leave the menu button on CDRIP.SKIN set to the default which is "Esc"
    Please help.
    Dec 2005
    That lloks like it works, but it doesn't really. If you look on the task bar or check in task manager CDRip the program doesn't launch. The skin launchs fine but not the program
  1. Release - MC2.0 Skin
    By CdRsKuLL in forum RR Skins
    Last Post: 04-09-2011, 06:56 PM
  2. Mazda 6 console skin
    By DiNASTY in forum RR Skins No Longer Supported
    Last Post: 04-16-2009, 06:06 AM
  3. SS Skin
    By sorensilk in forum RR Skins
    Last Post: 03-18-2007, 01:10 PM
  4. Replies: 2
    Last Post: 01-05-2006, 04:04 AM
  5. Strange problem with CDRIp
    By J187 in forum Road Runner
    Last Post: 07-09-2005, 08:53 PM
