Originally Posted by
Chuck
My weather button
"XMFAV||MENU;XM weather.skin;XM||XMCHAN;213"
The first command “XMFAV” will switch the xm play list – for this to work properly set your xm up with only one play list so xm will toggle between all channels and your favorites.
The next command “MENU;XM weather.skin” starts xm weather menu with all the weather channels – from here you can go to sports and news channels.
The next command is just the talk Xm – should change to xm weather if you use voice enabled in RR config.
The next command “XMCHAN;213” changes xm to your local weather channel
The rundown
When you push the weather button xm switches to all channels then starts weather menu and tunes to your weather channel.
When you hit the exit from xm weather menu it will switches back to your favorites list and to your previous channel and back to xm skin.
On my next skin update I will put localweather in the ExecTBL.ini so it will be better to change your local weather.
