Results 1 to 6 of 6
Thread: Skin "TIMER" events
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    Skin "TIMER" events
    I've found the TMR event that you can add to a skin, to execute something xxx seconds after the skin is loaded/run.
    It appears as though providing 0 is not acceptable, I have to provide at least 1 second.
    Is there any way to execute a command the exact instant I load a particular skin?
    Thanks!
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    well that depends, you can execute a command from any button that takes you to another skin by putting the commad after the load xx.skin command. But if you want to say execute a command when the skin first loads i dont know any other way other than w the timer.
    beer replenishment fund
    mp3car live search
    Apr 2005
    Southern Califorina
    *nod*
    That's pretty much what I thought.
    I suppose I could rethink my plans.
    What I wanted to do was trigger an event in girder, so that each skin, would have it's own input profile.
    Technically, if I'm inputting commands from girder, I could just add that as another action for the same event. But I was worried about cases where girder would send the command to RR, and for whatever reason, it may not actually load the requested skin. Then I'd have my controls setup for a skin I'm not on!
    Eep!
    Check out my blog.
    May 2005
    Vienna, VA
    Do something like this.
    In ExecTBL.ini, define a skin-specific command like this.
    "DO_THIS", "RR_command_here",audio_player.skin
    "DO_THAT", "Another_command_here",video_player.skin
    Then have girder execute "DO_THIS" when you push a button. This way, the command only gets carried out when audio_player.skin is active.
    You can have the same button trigger "DO_THAT." Depending on which skin is currently active, only one command gets carried out (or none at all if both are not active).
    However, this method will get cumbersome and out of hands quickly if you have lots of skin-specific commands.
    I humbly suggest guino add support for sending skin-specific commands to RR from girder (or an external app).
    Somthing like this would work.
    "Next;audio_player.skin"
    This way we don't need to define these commands in ExecTBL.ini.
    Apr 2005
    Southern Califorina
    Ohhh yeah..
    That's much more elegant!
    I think I'll give that a try.
    Thanks for the pointer. :-D
    Check out my blog.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the reason why 0 doesn't work is maily because RR will only load a screen when a load command has been issued -- in which case, you could add the command you wish to excute right behind it using the || command separator.
    Ride Runner RR's Myspace
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 01:51 AM
  2. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  3. Thoughts on skin design guidelines?
    By Arathranar in forum RR Skins
    Last Post: 06-13-2005, 05:54 PM
  4. Frodoplayer 1.0.9 Skin Released
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 02-13-2005, 10:38 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 09:50 PM
