Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: "radiator" for radioShark development
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Exclamation RadioSHARK Plugin for RoadRunner
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    if you look under RR's source there's a "Base Skinnable Plugin" which should allow you to build a integratable-skinnable plugin.. I can help you put it together, but when it comes to testing/debugging, I have no means of testing it without the hardware.
    Ride Runner RR's Myspace
    Elsewhere
    YEAH!
    Buy Guino a RadioShark!
    How about the Wiki?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    just send me the VB activex/dll you have along with a brief description of functions and I can work out the basics for you.. then you can just modify/improve upon as you'd like.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll check it out and let you know.
    Jun 2005
    Quote Originally Posted by Evolution VIII
    I'll be waiting.
    Thanks for your help.
    I will be waiting, too :P
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    The only questions I have are: how's the reception in a typical driving setting, and how can I get my car's antenna plugged into it?
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    guino,
    Never mind... I looked the base plug-in code and already figured out what to do. The code is pretty easy to understand.
    People, radioShark plug-in is coming soon!
    Where the plug-in must be installed?
    How to load plug-in from the main menu?
    Awesome news Evolution VIII.
    I can't wait till my unit arives this week to try it out.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by xs10x
    Does that mean you'll have it in by Saturday for the Atlanta meet?
    CiE
    CiE is offline
    Sep 2005
    Hooking up radio shark to your car antenna
    Hark it's very simple man open the casing theres only one screw in the bottom under the label and then just pry the two half's off. then theres one thick wire that on the board says FM. Goto radio shack spend 3 bucks buy a solderless motorola jack. then get home get the thick copper wire and just screw it to the motorola jack as if it was a whole cable. (there is a screw there just unscrew the piece and u will see a little screw to hold the wire) and thats it your done.
    I tried this already to compare and i had one radiostation that all i heard was static then all i did was hook it up to the car antenna and boom i heard it crystal clear. I'm waiting on my DSATX thats why i have't tried it moving in my car but i'm sure it will do the job decently.
    (BTW theres a forum about those instructions already)
  1. Hardware Development Links
    By lgbr in forum Hardware Development
    Last Post: 01-07-2007, 12:57 AM
  2. FREE Visual Basic .NET SE & ASP.NET Development Book
    By hevnsnt in forum Software & Software Development
    Last Post: 10-06-2004, 11:22 AM
  3. mini projects sub-forum in software development forum
    By stevieg in forum Mp3car Forum Suggestions/Comments
    Last Post: 06-06-2004, 07:01 AM
  4. AIS back in development again
    By Seraph in forum Software & Software Development
    Last Post: 02-14-2004, 11:25 AM
