Results 1 to 10 of 18
Thread: Any ipod users w/ RR please read
    May 2005
    I posted another thread in the Operating System forum, but I figured other people might have the same problem (environment is more similar)...
    Hey guys - 'd but didn't find anything ->
    Carpc specs:
    Dell Inspiron 8200 w/ 1.7GHz P4
    512 MB RAM
    20g HD
    SB Audigy 2 PCMCIA sound
    Xenarc 700TSV
    Usb Mini keyboard
    Linksys G USB nic
    Holux GR213 GPS
    40Gig ipod photo
    (everything is USB1.1, no usb 2)
    Software wise (autorun on load)->
    Windows XP + SP2 (no nlite or anything), Road Runner (11/27), iGuidance, SB Audio drivers/etc, Linksys NIC tools, StylesXP, and SAV (symantec antivirus)
    On resumes from hibernation, total time is like 15 sec (probably a little more, but I'm not too concerned with this), but...
    With the iPod plugged in, once windows loads, my lappy just freezes for like 2-3min, then comes back to life and continues as normal
    Without the iPod, once windows loads, everything is good to go.
    I've never installed iTunes, but have the latest winamp (5.12 i think) + I've had the mlpod plugin (uninstalled now).
    I thought it was RR, but whenever the ipod is gone, everything is fine (RR supports ipods, so i took off the mlpod as guino suggested)...
    I think it might be a problem where windows keeps scanning the ipod for something like the autoplay (on usb 1 maybe it takes longer), but no autoplay window pops up (I have it disabled with TweakUI)...
    Anyone have this problem or know of a work around for it? Its starting to really suck on short drives, where by the time the pc gets loaded I have 2 min till i shut down again.
    Thanks ahead of time
    -Pete
    (iPod stalls computer on resume from hibernation)
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    There is a windows bug where if you hibernate without a USB device plugged in... and then plug in the device before you resume from hibernate.. it will stall on resuming from hibernate...
    I noticed this issue on my work laptop... there is NO fix for this that I have been able to find.. except for not plugging anything in until the pc has fully resumed.. or alternately... not plugging anything out until i am done hibernating
    May 2005
    That's what I've read too, but I leave the ipod plugged in on resume/hibernate (its in my car all the time), and the problem still happens
    Aug 2004
    Pearland
    in that case... I suggest using Devcon to disable it before you hibernate... and then use Devcon again to enable it on resume...
    May 2005
    I read up on the documentation, but when I run -
    devcon disable *IPOD*, it says
    USBSTOR\DISK&VEN_APPLE&PROD_IPOD&REV_1.62\000A2700 02C73C3D&0: Disable failed
    No devices disabled.
    Am I doing this wrong?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    you dont disable the ipod you dissable the port its pluged into and it will be a PID number most likely. This is the comand that dissables my GPS mouse.
    "c:\devcon\i386\devcon disable *pid_2303*"
    the pid_2303 being my com port 4 which wont be the same port that your after, you will have to find that out for yourself.
    May 2005
    I did a "devcon status usb*" :
    USB\VID_0409&PID_0058\5&19D40361&0&1
    Name: Generic USB Hub
    Driver is running.
    USB\VID_0D7D&PID_0150\143608014E1D
    Name: USB Mass Storage Device
    Driver is running.
    Name: Apple iPod USB Device
    Driver is running.
    and tried disabling : "*ipod*", "USB\VID_0D7D*", "USB\VID_0409*" and basically any PID listed as combinations... everything returns "disable failed"
    Aug 2004
    How do you find the pid ?
    May 2005
    derr... I'm an idiot - right now I'm trying this on my work computer, and I'm not an Admin... tried it on a diff computer as admin and worked like a charm....
    Laguna: you run "devcon status usb*" or "devcon find *" and it'll list all the devices attached... then you just narrow it down to what is plugged in... now i can do a "devcon disable *ipod*" and that'll disconnect the ipod
    thanks guys.. I'll give this a try in my lappy when i get in my car
    May 2005
    Tried it, but the laptop still stalls... i guess there is no hope?
  1. Apple releases the new iPod Nano
    By psykopyro in forum Off Topic
    Last Post: 10-19-2005, 09:49 PM
  2. Nokia users read this
    By zorro in forum PhoneControl
    Last Post: 08-07-2005, 10:40 AM
  3. iPod and VW bug: Will this work ?
    By archie2u in forum Newbie
    Last Post: 08-03-2005, 11:17 PM
  4. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 10:32 AM
  5. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
