Page 6 of 6 FirstFirst 123456
Results 51 to 59 of 59
Thread: RR vs Frodo
  1. #51
  2. #52
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    Last night I hooked up some temperature sensors, then figured out how to edit the LSX skin to change the time & date display to the output of these sensors. This took a grand total of ten minutes.
    Last week I put in a RadioShark, along with a phidgets relay board to control the power antenna. I set these up so that when I go into the RadioShark plugin, my antenna goes up, and when I exit, it goes down. This all took 2.5 hours, and this was the first time I ever edited a skin.
    From the community that pumps out plugins and skins non-stop (not to speak of our bionic coding-slave, guino) to the functionality and versatility of the application itself, Road Runner is hands-down the best carputer solution.
    Frodoplayer is a good "out-of-box" solution for novices and for those times right after you installed your system and just want it to work now. RR really does require some effort to taylor it to your own needs.
  3. #53
    Variable Bitrate pcfreak's Avatar
    Dec 2005
    Freeport, IL.
    Quote Originally Posted by Quattro
    I currently use RR, but hate playlists. There needs to be a more simple way to just play one album.
    FP does a better job at this, but it lacks many things RR does. So I'm split between RR & FP, but I haven't really played around with RR.
    I do not understand.... I have one playlist, I rarely play it. All my songs/mp3 files are all organized by artist directorys. In each dir they are organized by cd's. IMO it does not get any easier to play one album. I mean after all, all I have to do is browse to that cd and load it. And as far as searching for a particular song goes, do you not know who sings the song? If you do then how hard is it to browse to it if your **** is organized? I guess I do forget very often that different people do things different ways. But I must say that the key to most problems in life can be fixed by one word, Orginization.... Like my dad always told me growing up, if you put the tool back where you found it son, then you'll know where to find it when you need it again. But any ways, I think RR is the shiznit of front ends, and I've tried every single freaking one of the front ends on this site, so I think in my opinion have the right to say that RR is the BossHog baby. Good luck in making your decision, cause you are the only one that can make that decision.
    Peese
  4. #54
    Jan 2006
    California
    I switched from FP to RR, my main reason was that RR uses winamp (which plays my songs quicker and there is a very tiny pause between tracks) whereas FP uses Windows Media player which would play my tracks but they would skip in the beginning (like a scratched cd, but these are mp3 files copied to the carputer).
    As for the database, i dont see what the problem is, as soon as you put a folder of songs in the directory where RR links to music it will show that folder, and you can just name it whatever the album is named
  5. #55
    Newbie millc5's Avatar
    Nov 2005
    CA
    Quote Originally Posted by guino
    It was made available for moderators to try it... I bet you're in raging in jelousy of xBrady right now.. hahaha...
    Thats a fact. I want to try the software out. I don't want to rip out my current system to do that.
    Looking forward to the mp3car community release of the unbundled software.....
  6. #56
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by IntegraKarim
    You can get rid of that by using a crossfader plugin for winamp.
  7. #57
    Jan 2006
    California
    Quote Originally Posted by Enforcer
    Lol, actually i meant its better because in windows media player it had a looonger pause before my tracks played. The tiny pause was a compliment, but thanks for the advice, where can i get the plugin, winamp.com?
  8. #58
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by pcfreak
    umm, I have my music "Organized" just like u do. Artist folder and then the albums within that folder. I don't know, with FP and the directory mode I just find it easier to go through my music. But the more I've been using RR, I'm begining to like it much better.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  9. #59
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I know that's what you meant, just thought I'd throw something at you that would get rid of them as well.
    Yes winamp.com search in the plugins for crossfaders there will probably be a few.
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. How i make Dabbar + Trinloc DAB usb work with frodo
    By MagikTriX in forum FrodoPlayer
    Last Post: 09-04-2005, 03:58 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
