Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Can someone help me get DVDs to play?
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    I have RR setup on both my home PC and carpc. I can play DVDs fine on the home PC but not the carpc.
    I've checked the settings on both and everything appears to be setup the same.
    I downloaded mplayerc.exe from the links page on guino's site and I've got the path setup right on both PCs in RRConfig.exe.
    I've got my drive letter setup on ExecTBL.ini in the skin folder.
    Code:
    "LOADCD","RUNQW;C:\Program Files\Road Runner\CFX_Tools\BATs\LoadCD.bat" "J||LOADLIST;C:\Program Files\Winamp\winamp.m3u;Audio CD||!BROWSE"
    "LOADCD_CANCEL","RUNQW;C:\Program Files\Road Runner\CFX_Tools\BATs\LoadCD.bat" "J||LOADLIST;C:\Program Files\Winamp\winamp.m3u;Audio CD||!BROWSE||CANCEL"
    I also have Windows Media player 10 on both PCs and I can play the DVD just fine in Media player 10. So it's not the drive.
    I tried running mplayerc.exe by itself and when I hit CTRL D to play I get this:
    http://img236.imageshack.us/my.php?image=prob2yl.jpg
    Any help would be appreciated.
    -Rich
    Oct 2004
    NY
    I had this problem & winded up having rr play videos with a different program, I think I used powerDVD..... you can set up rr to use a different app for videos than the included mpc....
    Dec 2003
    New Jersey
    Quote Originally Posted by turbocad6
    Damn, that's what I'll have to do if I can't get this fixed. Which is better for emedding in RR? WinDVD or PowerDVD? Got a screenshot?
    Rich
    FLAC J187's Avatar
    Nov 2004
    Boston
    Install the K-lite codec pack full. Then run fixcodecs (Comes w/ k-lite)
    Fixcodecs is not available through the start menu, its in the directory in program files after you install the pack. I think in the TOOLs folder. Anyway
    Detect broken codecs
    Enable all of the streams for ogg splitter
    Make sure to check boost AC3 volume
    http://www.free-codecs.com/K_Lite_Co...k_download.htm
    Make sure to choose full version
    That should solve the problem. Plus - Klite is an all in one solution for codecs - comes w/ Gspot too.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Dec 2003
    New Jersey
    Quote Originally Posted by J187
    Thank you, I'll try it now.
    Rich
    Dec 2003
    New Jersey
    Downloaded the full version and installed with default options. Then ran Fixcodecs with these options,
    But I didn't see what you meant by "Enable all of the streams for ogg splitter"
    And it still doesn't work.
    FLAC J187's Avatar
    Nov 2004
    Boston
    There will be options under OG splitter with check boxes, make sure they are selected. IT didn't work, thats a shame I thought it would.
    Please help.
    Oct 2004
    NY
    I'm using powerDVD on mine with no problems...... it works perfect & embeds perfect...... how it displays is pretty skin specific, but works fine.... I never could get it to work with mpc......
    Dec 2003
    New Jersey
    Do you mean when I'm installing it or when I'm running the fixcodecs program?
    Rich
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you need a AC3Decoder most likely.. the thing is that MPC has a built in AC3 decoder that should kick in unless you disabled it.. if you're having this types of problems, I'd suggest using powerdvd/windvd etc, at least until I build a WMP based DVD player.
    Ride Runner RR's Myspace
  1. Replies: 8
    Last Post: 12-20-2005, 09:13 PM
  2. Replies: 3
    Last Post: 04-12-2005, 09:26 PM
  3. Media Engine won't play DVDs??
    By sq_geek in forum Media Engine
    Last Post: 05-10-2004, 12:32 PM
  4. cant play dvd's on media engine 2.0
    By streetknight in forum ME Archive
    Last Post: 01-15-2004, 02:51 AM
  5. VIA m10000 can not play dvd's smoothly
    By -al- in forum General Hardware Discussion
    Last Post: 11-05-2003, 05:32 PM
