i just updated to the new RR and since doing so all my skins have a white box where the flash appears, sure im doing something wrong but im not sure what?
it was working fine before
any help is appreciated
Best wishes
Adam
Printable View
Best wishes
Adam
Update to the latest flash.
Actually I'd advise you to use the full MSI from Gunios post some where in here..
Terran
If you don't want the flash logo get rid of the line at the end of the menu.skin file.
it is the line after this one:
/, F, x, y, w, h, Movie name
Don't forget to do the same for the Audio_Player.skin or the white box will be there behind visulizations.
I just update my RR as well. The spinning logos all have a white background now. Was transparent before. Don't know how to fix it. Any other suggestions?
Follow the "Unresposive buttons, ... Flash Issues" FAQ... if your flash software is updated properly there's no reason why this should happen -- also, verify/try different Flash logos just to be sure it isn't YOUR logo that isn't transparent.
Thanks for the reply Guino. I went back and updated by flash player again, and all is well now! If you get a moment look at my other post about problems with the mixer. I cannot get the EQ or mixer controls to work.
I take it my first post was/is invisible then :rolleyes:
No, I actually used your advice. Thanks
Any suggestions on helping me fix my other problem with the mixer and EQ?
http://www.mp3car.com/vbulletin/road-runner/69027-problems-with-mixer-and-eq.html
