There are no current plans to add support for other tags in RR. If you want to use tags in different formats you're limited to do so by using the winamp library support -- Have winamp load/index your files in the winamp library, then load the songs using the -- Artist/Genre/Album -- entries in the audio browser.. when RR loads those entries into the playlist, they'll have the Tag info that winamp read from them. Other than that, you can make playlists with extended tag info, and RR will load those straight into the playlist without reading the files.
LinkBack URL
About LinkBacks
