Results 1 to 2 of 2
Thread: noob question temp sensors
    Low Bitrate yamathegreat's Avatar
    Aug 2004
    calgary, alberta, canada, cold
    of so i have the phidget 8/8/8 board and my tempsensors pluged in and i trying to get them to show up in rr but so far i cant get it working im very sure that im doing somthing stupid! so.... in the phidget webservice app in the taskbar the port is 5001... now in the rrconfig app it askes the com port number and im assuming that it dosnt want the port from rr cause thats not really a com port right? so what com port do i want? now i know it will be different on every computer so how do i come up with this com port? im assuming this should be an easy task as it's built in.... but i still need help! pls!
    thanx in advance
    -jeff
    Oct 2003
    Copenhagen, Denmark
    RR does not use the phidget webservice, it uses the api interface, all you need is to install the phidget.msi file from phidgets and then create the visual part in the skin.
    This is part of my menu.skin in the brushmetal skin, phidgets are defined as labels for displaying volt/temp and so on.
    /, (L) Label
    /, x y w h r g b pt font Code tooltip
    L00,430,440, 50, 30,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
    L01,025,010,200,030,255,255,255,18,"Arial Narrow:B","TIME","Time"
    L02,025,040,200,030,255,255,255,18,"Arial Narrow:B","DATE",""
    L03,630, 10,100, 30,255,255,255,18,"Arial Narrow:B","=ZPA03:", ""
    L04,720, 10,100, 30,128,255,128,18,"Arial Narrow:B","PHID04", "volt"
    L05,630, 40,100, 30,255,255,255,18,"Arial Narrow:B","=ZPA05:", ""
    L06,720, 40,100, 30,128,255,128,18,"Arial Narrow:B","PHID02", "f2c"
    Not doing carpc anymore
  1. Another noob question
    By Pokiarchy in forum Software & Software Development
    Last Post: 11-16-2005, 06:44 PM
  2. New Noob Question
    By JackyD in forum FrodoPlayer
    Last Post: 08-18-2005, 11:07 AM
  3. Dumb noob question
    By TaZMaNiaK in forum FrodoPlayer
    Last Post: 04-02-2005, 12:52 AM
  4. Noob Opus wiring question..
    By kuwupt in forum Power Supplies
    Last Post: 11-01-2004, 01:21 AM
