Results 1 to 10 of 15
Thread: RoadRunner Freezing
    Feb 2006
    RoadRunner Freezing
    I have a Via M1000 mobo, 512mb ddr ram... RoadRunner is running at 95-100% all the time.. I have tried other front ends and they usually run around 20%. Does anyone know what is causing this problem.
    Also the volume increase and decrease button in roadrunner are not working all the time. Sometimes it lags and sometimes the volume is 100% and when I drop it down, it mutes the volume.
    Raw Wave
    Jun 2004
    On the beach
    READ THE FAQ! ITS NOT DIFFICULT!
    The answer is here!
    High CPU Load, Buttons Fail to Respond, White box / square around logo's
    Install the latest version of flash!
    Low Bitrate tasteItheIvalue's Avatar
    Nov 2005
    Connecicut; United States
    are you running a visualization?
    Feb 2006
    Actually I am not running a visualization and the flash support did not fix the problem...
    Raw Wave
    Jun 2004
    On the beach
    But is it the latest version of flash? Have you tried other skins? Which skin are you using? Which version of winamp? Which version of RR?
    Feb 2006
    Actually the latest version version of flash, Using CFX skin, Winamp 5.13. RoadRunner version RR 01-15-06
    Couple of other problems too
    In Iguidance external gps mode, when I click full screen It says GPS loading but never loads
    The volume increase and decrease buttons are not working all the time.. They are lagging
    Raw Wave
    Jun 2004
    On the beach
    Have you tried another skin??
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    install flash with IE... thats the only way the update works.
    Feb 2006
    I tried the BMV2 skin and it does the same...
    Nov 2005
    use winamp 2.9, try using igmod for iguidance, it blends in very nice with cfx skin (the blue one is obviously the best with igmod). your volume controls lag due to the CPU usage. i used to have the same problem you had... all i did was update my flash via a version posted in a thread here, not through macromedia.com and switch to winamp 2.9... give it another go; hope all works out well.
    and fyi my setup is just very similiar to yours (m1000 512mb ram); the only time i am up at 90% usage is when i am running milkdrop vis.
    goodluck
  1. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  2. RoadRunner and Freedrive at Startup
    By Cruizer in forum Road Runner
    Last Post: 11-18-2005, 04:35 AM
  3. Mediacar skins on RoadRunner?
    By kameleon in forum Road Runner
    Last Post: 08-20-2005, 09:54 AM
  4. HORM and RoadRunner...
    By CornFlake340 in forum Road Runner
    Last Post: 04-14-2005, 05:17 PM
  5. roadrunner problem
    By i3igmind in forum RR Bug Tracker
    Last Post: 03-19-2005, 05:03 PM
