Results 1 to 7 of 7
Thread: Couple of RoadRunner Questions & Problems
    Feb 2006
    1. My Car logo image always displays white box.. Does anyone know what is the problem and know how to fix that??
    2. When I play XM radio the Sat and Terrain green bars are not in a straight line, they are messed up..
    3. When I browse through the menu's there is a 2-3 second lag.. Is that common?
    4. How do I exactly integrate igmod? when I do external application > Igmod, a new window opens up.. It does not integrate
    I have searched a lot of times for these problems and havnt found the solution... Thanks For helping!
    Sep 2005
    Also want to know like a DIY of how to properly install IGmod, bump
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-Likely your flash file is not transparent or your flash version is too old. Try another flash logo (like the honda from the bmv2 skin) and if the white square still shows it will be an indication of a bad flash version (which may lead to CPU load issues)
    2-This is a skin issue. You can fix it yourself (using the skin editor) or report the issue to the skin's author (which has no obligation to fix it)
    3-It is common for a delay to exist when loading new screens for the FIRST time. After which, they should load instantly. If it is taking longer to switch between screens that already have been loaded, it may be because of your flash version increasing CPU load. Please read the ENTIRE high CPU/Flash FAQ -- specially in what it regards to Via 4-in-1 drivers and Video card drivers.
    4-Never used it, so don't know anything about it, but there's plenty of info in the GPS subforums.
    Ride Runner RR's Myspace
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    also, if your logo's not flash, you need to save the pic in a program that supports transparent backgrounds, in a file format that supports transparent as a color. I think Gif supports transparancy, or tiff. Try using The Gimp as an editor if you don't have one that does transparancy.
    Feb 2006
    Can someone suggest me a good Toyota Flash logo?? And also exactly in which folder, do I copy it to?
    FLAC mauri's Avatar
    Jan 2004
    Update the Flash Player with v.8 version.
    Mauri
    Feb 2006
    Actually I updated to the latest version of flash..
  1. Couple of Audio Questions
    By CAA in forum General MP3Car Discussion
    Last Post: 01-19-2006, 09:09 AM
  2. Couple of XM radio Questions....
    By BoOsTin FD in forum General Hardware Discussion
    Last Post: 06-11-2005, 01:02 AM
  3. A couple questions....
    By gothate in forum Road Runner
    Last Post: 05-28-2005, 10:23 PM
  4. Couple of questions
    By oekundar in forum General Hardware Discussion
    Last Post: 09-03-2004, 11:45 AM
  5. Couple of questions..
    By TimW in forum General Hardware Discussion
    Last Post: 03-17-2000, 11:42 AM
