Results 1 to 8 of 8
Thread: Eject with a usb cdrom drive
    Feb 2006
    Belgium
    Eject a usb cdrom device
    Hi,
    I've a little matter with RR and my usb dvd drive. The dvd drive is a LG DVD-Rom Ide, and I use a USB-to-IDE Adapter USB2.0 for converting it into a usb device.
    http://www.cartft.com/catalog/il/381
    When I press the eject button on the screen, nothing happen, the dvd doesn't eject. But when I connect it with IDE (no adapter) that's work great.
    Any idea of the problem ?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've never tried Eject with a USB drive, dont see why it shouldn't work. The only limitation of the EJECT command is that it will only work with the FIRST removable drive installed. RR uses a Built In WINDOWS function for this feature, so there's hardly anything I can do to improve it.
    Ride Runner RR's Myspace
    Feb 2006
    Belgium
    Quote Originally Posted by guino
    I don't understand why that doesn't work. When I go back home, I'll try to eject a disc with the button in the windows explorer (Right clic on the device, Eject), to see if it works.
    I'll keep you update
    Thank you
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Please do,i plan to use the usb adapter too.
    Banned Hwonder's Avatar
    Nov 2005
    NC
    I hav had that problem in the past, so I decided to make a little app that you can run to open the cd/dvd drive. Edit your *.ini to point to it when you press eject, or set it up as an external application. Good Luck!
    http://carpcdomain.no-ip.info/cpcd/cdopen.zip
    Nov 2005
    Midlands
    Thanks Hwonder
    Feb 2006
    Belgium
    Quote Originally Posted by Hwonder
    Great Thanks.
    I've find how this problem happen. Sometimes my usb 2.0 hub disconnects my dvd drive for any reason . I'll try to fix it by adding a power supply to the hub.
    When the dvd drive is correctly connected, RR eject the dvd with no problem. Sorry for thinking that was a RR's problem, that was not the case.
    Nov 2005
    Midlands
    i've been having similar usb problems lately,not on my install thank god but my brother inlaws,he was basically trying to pull too much current through his available usb ports.RR would function normally until he activated his WinTv tuner and then he'd lose the touchscreen controller,a powered hub fixed the problem.
    also,when this happened you could hear that Windows sound of a usb device being hot swapped,over and over again.
  1. USB DVD drive not reading dics
    By 04scooby in forum General Hardware Discussion
    Last Post: 03-01-2008, 06:30 AM
  2. How to relocate xbox dvd drive? IDE to usb?
    By osnola22 in forum Hardware Development
    Last Post: 06-26-2006, 12:40 PM
  3. Replies: 5
    Last Post: 05-21-2005, 11:59 AM
  4. problem with my usb to ide cable. high speed usb drive?
    By DSM97RS in forum General Hardware Discussion
    Last Post: 05-19-2004, 01:10 AM
  5. External USB drive
    By mtmsol in forum General Hardware Discussion
    Last Post: 11-27-2001, 06:25 AM
