I'm willing to help you, but You've gotta give me something to go on... Did you install RR, from where? How did you install it? What is going wrong? When you click on RR.exe what happens? Is there an error message?
I'd like to start this thread off by saying YES I have read all the FAQ's! I spent the better part of 5 hours doing NOTHING BUT READING. I am tryingto load road runner and set it up as my front end with NO LUCK. If there is anyone willing to help I would really appreciate it.
I appreciate you taking the time to help.
I downloaded RR from the RR Site. I used the "dummy proof" version that walks you through it. Installshield.
Soon as I click on it I get a message that says C:yada yada yada / does not contain a valid skin. Check your settings and try again
look in c:yada yada yada skins\ and see if you have a folder called brushmetalhonda
if so then look in it and see if it has a file called
general.ini
if so then open general.ini and see if it looks like
Code:[General] OriginalWidth =800 OriginalHeight=600 ShowWidth =800 ShowHeight =600 XPosition =0 YPosition =0 [Gamma] ApplyToVideo =False ApplyToVisu =False AutoSwitch =False DayTime =8:00:00 AM NightTime =6:00:00 PM GammaDayRed =1 GammaDayGreen =0 GammaDayBlue =0 GammaNightRed =-40 GammaNightGreen =-40 GammaNightBlue =-40
if you don't have that folder, file or it doesn't look like that then you need to go to guino's site and download the brushmetalhonda skin or download any other skin, run rrconfig and point the dayskin to the skin you have just downloaded, remember you need to unzip the skin to the skin folder.
Only thing in skins is a folder thats labeled
C:\Program Files\Road Runner\skins\BMV2
IN my config file for skins it says: C:\Program Files\Road Runner\skins\BMV2\slider_battery\
Just downloaded your idrive skin and unzipped it to my "skins" folder. Which item goes into my RR Confing ???
Originally Posted by BADEVO
change that to C:\Program Files\Road Runner\skins\BMV2\
Originally Posted by bad-at-this
Sweet deal! That worked.
Just for future reference, when I download a skin, what command goes into my skin path in RR Config?
when you run rrconfig, where it says skin if you click on the file path it will bring up a browse dialog, browse to road runner\skins\iDrive so thatOriginally Posted by BADEVO
C:\Program Files\Road Runner\Skins\iDrive\
appears in the box, then click save
You guys are great man. It's people like you that make this forum succesful and I appreciate it.
