Great work. Can't wait to try out.
Well guys, this is my little contribute to RoadRunner
I have worked to solve the followings issues that I have noticed in the PHOCO integration:
-Fixed issue with the indicator "BOTTOMPL" that doesn't work
-Fixed issue in "CHOOSE_NUMBER" skin if the phone support contacts with more then 4 numbers stored
-Fixed other minors bugs in contacts handle
-Added "NUMBER_FAX_PHOCO" and "NUMBER_OTHER_PHOCO" commands and labels (see Skin Commands.txt for more details)
-Fixed issue in "CALL_OUT" skin that sometimes doesn't show the name of the contact called
-Added auto exit in "CONTACTDETAILS" when save a contact
-Added "phoconoincallevent" setting in RR.ini to disable the InCall event, that is used to determine if someone accept the calls directly on the phone and not through RR, but that it may create problems whith thats phones where this feature is missing (like some Sony Ericsson). So if you have noticed that before you have accepted an incoming call your skin change in "IN CALL", try to add phoconoincallevent=true in your rr.ini or set it in RRConfig.
-Added date in calls lists.
-Added date visualization in calls lists and sms lists based on the date format in RR.ini
-Fixed issue with deletion of contacts and SMS
-Fixed issue with duplicated visualization in SMS and calls lists
-Fixed issue with "Delete" command that doesn't refresh the SMS lists
-Added "SHOWRECEIVEDSMS", "SHOWOUTGOINGSMS", "SHOWSENTSMS" and "SHOWARCHIVEDSMS" commands (see Skin Commands.txt for more details)
-Added new settings in RRConfig to handle the new PHOCO integration.
-Fixed issue with using the latest versions of PHOCO
- UPDATE -
Download binary: RoadRunner 02-19-06.zip
Download source: RoadRunner 02-19-06 Source.zip
Thanks for your contribution... I see you did a good job marking the places you made changes (modPhoco, modRoadRunner, frmLoader and frmSkin). I'd like for some people to help test those changes so I can merge them with my latest changes, given that most changes are on the SMS support, I don't foresee any problems..![]()
Ride Runner RR's Myspace
Thank you Guino![]()
I can see that you have already seen all the changes I've maked, so if there is something of incomprehensible, please don't hesitate to ask to me... I will try to answer you with my very bad English![]()
Please note that I,ve maked some changes in RRConfig (frmMain.frm)... don't forget to marge this too![]()
and who says newbies dont contribute
nice job!!
beer replenishment fund
mp3car live search
nice work..
ill try it out
Looks good, thanks for the hard work but I'll wait till Guino integrates it with his release to use in the car.
don't be put off by this response,its great to see new guys here helpin out,after only 3 posts tooOriginally Posted by Gobby
