Results 1 to 5 of 5
Thread: Sending girder variables to display in RR?
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    As the title says, is there any way to do something like this?
    Here's the scenario:
    Since my input buttons are limited to under 14 functions, I have my girder setup to toggle button functions -- effectively expanding the amount of buttons available to 28. In order to track the current 'toggle' mode though, I have to be able to determine between mode 1 and mode 2. Unfortunately, there isn't a persistent display from girder, just one that flashes by when I push the toggle button. What I'd like to do is put a display unit showing the 'toggle mode' in RR so I can remember which mode I'm on.
    Hope someone can help?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The best thing for you to do is to map each button to a SPECIFIC "CUSTOM" command in girder, that is, instead of mapping button 1 to "PLAY", map it to "BTN1"... do that to all 14 buttons (up to "BTN14").. of course, those commands don't exist in RR, but that's when you go into ExecTBL.INI and define their functions, best of all, on a PER SCREEN BASIS. This allows you to use your 14 buttons for completely different functions on EACH SCREEN, for instance:
    "BTN1","PLAY",audio_player.skin
    "BTN1","BROWSE",audio_browser.skin
    "BTN1","PAUSE"
    and so on.... note that button 1 above will be "play" on the audio player, "browse" on the audio browser, and "pause" on EVERY OTHER screen. You can define the functions globaly or on a per-screen basis until you've achieved the desired setup. This eliminates the need to use "groups" in girder and eliminates any doubts as to what function will be performed by each button.
    Ride Runner RR's Myspace
    Jul 2004
    Los Angeles, CA
    Guino,
    Thanks so much for your suggestion; I have seen that suggested in a couple other threads in this forum.
    Unfortunately for me, since my hotkey setup is rather elaborate, there are occassions when I must rely on the same key to do different functions on the same screen (scroll up/down in a list vs. scroll left/right through the buttons). I'm using a sort of toggling jog dial for this feature. Considering that, your useful suggestion doesn't quite work in this scenario (unless I'm missing something?).
    On a similar note though, is there a way to define a list object to have TWO highlight colors in a skin? One for the default highlight color and a second highlight to illustrate focus for hotkeys.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Lists are limited to one highlight color.
    You can probably display your girder "state" by making your "switch group" button create and delete a file (or rename the file back and forth), and have RR monitor the existance of the file with a File indicator that you can place on your skins. You can probably rename the file by running a .bat file for instance.. this is a little complex, but so is your control methods.. your easiest choice would be to get a bigger remote.
    Jul 2004
    Los Angeles, CA
    Quote Originally Posted by guino
    Unfortunately, I can't get a bigger remote, I'm using the OEM buttons on the headunit
    Thanks for the idea. I'll try it out!
  1. Display the version of RR
    By slimmegane in forum Road Runner
    Last Post: 04-08-2005, 11:25 PM
  2. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 12:47 AM
  3. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 08:14 PM
  4. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 09:14 PM
  5. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 10:43 PM
