Results 1 to 10 of 11
Thread: Issue with microphone on laptop...
    Feb 2006
    Minnesota
    Sorry for the new thread, i did search for this problem too...
    Im running RR on my laptop, and if i dont mute the microphone that is onboard, then there is static in the background... So i go ahead and mute the microphone in the volume control. and it sounds great.
    But when i adjust the volume in RR it just unticks the check box for the microphone mute and adjusts the slider with the volume slider.
    is there any way around this? thanks again!
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Click START>CONTROL PANEL>SOUND AND AUDIO DEVICES. Under Volume click Advanced click options, click Properties click Recording and uncheck Microphone.
    Feb 2006
    Minnesota
    So is there anyway to like disable or uninstall JUSt the microphone without distrupting the regular sound card?
    Feb 2006
    Minnesota
    Quote Originally Posted by MGD
    Yeah, in my first post i said I muted the microphone.. but when i adjust the volume in RR it just takes over all the sliders in the volume control and adjusts them up and down together.
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    I did not say MUTE the microphone. If you follow the instructions it will uninstall the microphone as RECORDING device.
    In RR Config under Music Select Mpa Master Volume to Line and select Master Volume
    Feb 2006
    Minnesota
    Your first suggestion did not work, probly because i have windows 2K.. but your second solution worked.. I didn;t even see that option, kinda wierd cause i looked over that config menu so much. but thanks alot! way better now.
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    You're welcome, and have fun with it.
    Feb 2006
    Minnesota
    Well now its not altering the microphone volume... but its now defaulting the balance to "left"... its odd. I set it to center in voulme, then as soon as i adjust the volume in RR, it goes to left balance.. any ideas?
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    Man... you have a weird sound card or something! :P
    K301 7" Motorized Screen
    Mini SLIMPRO SP625 Cappucino PC
    RoadRunner / IGuidance 3.0
    Pioneer 7700MP HU
    MTX 1500D 1500 Watt Sub Amp
    2 x 12" MTX 8000 subs
    1998 Olds Aurora 4.0 V8
    Feb 2006
    Minnesota
    well i think i got it. i just set "setbalance;50" and assigned a key on my remote to this function. and once i turn my volume up past 0 and then press the button, it stays balanced the rest of the time. its wierd. sorry if that was confusing, but i figured it out!
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Logitech "noise-cancelling" microphone
    By evandude in forum Input Devices
    Last Post: 10-24-2007, 07:08 PM
  3. Replies: 8
    Last Post: 01-24-2006, 11:43 PM
  4. Xenarc Touch screen issue with SONY T-140 Laptop
    By riuster in forum LCD/Display
    Last Post: 07-22-2005, 11:52 AM
  5. disabling laptop ibm T42 onboard microphone.
    By WhiteRabbit in forum Input Devices
    Last Post: 12-01-2004, 08:27 PM
