Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Video not playing, help wanted
  1. #21
    Jan 2006
    alright this thread is dead. I cant figure out why its not working on my work pc, im guessing it has something to do with the Quadro drivers. But I have gotten it to work on three other comps in the last hour. So im not worried about my car pc atm. I used a different codec package though on the other three, instead of useing K lite I used Ace and it works flawlessly. In my opinion it was a little more in depth as far as its selection on drivers. Thank you for all of your help guys. Now that I see how things are supposed to run I can see the stupidity in my problem. I got way to in depth trying to fix a very very simple problem.
  2. #22
    Low Bitrate mobileT83's Avatar
    Jan 2006
    Western MA
    I had the exact same issue....outside of RR I could play all the videos in my MPclassic with the k-lite mega codec package. but then when I tried to play them in RR they just wouldn't show up in the playlist. What I did was, read your posts.....got nothing, then wondered if the reason they weren't playing was they were not on the extension list in RR. Well there are too many extensions to list and each one had its own little eccentricities so I just cleared that field in RR. Low and behold everything showed up and all of them play.
  3. #23
    Jun 2007
    I had this problem too and have been messing with it the past couple of days. As soon as I clicked the video browser, RR crashed and burned. As soon as I uninstalled the K-lite Codec Pack, everything worked flawlessly. If other users are having the same issue, look at your codec pack first.
  4. #24
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    First of all. If you are using the built in player large video files over 100 mb will not play. Second, if you are using MPC. Make sure u dont use sytem default but use Video Overlay in the configuration and save. Also make sure you put in video extenstion that you want to use. Ex: *.avi, *.wmv, *.mp4, Etc...
  5. #25
    Aug 2006
    I had same problem on my Epia MII. for some reason the video in RR was being sent to the composite tv out. Had to remove second display and disable RCA video on the motherboard to get it to work.
  1. Trouble with PCI video card install ... help!!!
    By DonkeyBoy in forum General Hardware Discussion
    Last Post: 08-10-2005, 05:22 PM
  2. Playing Video
    By FunkDaMonkMan in forum FrodoPlayer
    Last Post: 05-09-2004, 06:43 AM
  3. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
  4. Weird problems with video and ME 2.1
    By Rireal in forum Media Engine
    Last Post: 02-20-2004, 07:33 PM
  5. TV-OUT video card wanted
    By detz in forum Classified Archive
    Last Post: 07-10-2002, 03:08 PM
