Results 1 to 10 of 11
Thread: Sliders that move when you click them
    Sep 2005
    UK
    I am sure this is a very n00b question but I am having no end of problems with trying to get it work.
    My two examples are volume and song position.
    I have a volume slider and a song position slider that move when I increase/decrease the volume and when the song postion changes
    However I want to be able to click on the location on the slider and it jump to where I click to on the slider.
    Looks like everyone has done this on there skins but I can't for the life of me figure out how.
    I can't imagin this is going to be a large post but I am sure I will feel a tw4t by the end of it.
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    press and hold the slider... what happens? are you making your own skin?
    Sep 2005
    UK
    Actually I was modifying a skin. Which was strange because it all worked fine to start with then as soon as I moved a few things about it stopped working.
    I have tried to get this working just with a blank skin with nothing in but a slider. And I can't even get that right.
    What objects do I need in a skin to make a song position slider that I can move?
    thanks
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Post your SLIDER Code. It should look something like this.
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,22,479,228,15,22,479,228,15,H,01,"slider2\Poin ter.gif",30,"MASTER",
    May 2005
    Vienna, VA
    Post the original code and your code. We'll probably figure out what went wrong.
    Sep 2005
    UK
    Don't worry guys, not to be beaten I have gone back to it and fugured it out.
    I didn't realise the purpose of the x2,y2,h2,w2 fields.
    It seems on the skin I was modifying I moved the slider but failed to move the above fields accordingly.
    I have a bad cold at the moment so I would like to officially use that as my excuse for stupidity.
    Thanks alot for all you help
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Glad you figured it out.
    Sep 2005
    UK
    Actually a slightly related question.
    For my volume I increase both the master and wave volume at equal amounts so I get a better difference between each increase and decrease of the volume. At the moment I use a button and VOL-||VOL-;Wave","Volume-. Can anyone think of a way I may be able to get a slider to do the same thing?
    I have tried putting MASTER||WAVE in the code field.
    I have also tried putting two sliders in one for master and the other for wave and overlapping the x2 y2 fields.
    Any other ideas are apriciated.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Glad to see you at least thought about work arounds.. Two sliders on the same spot should work.. what happened when you tried that ? Did you define a pointer file for both, and defined all areas equally for both ?
    Ride Runner RR's Myspace
    Sep 2005
    UK
    What happens is only the first defined slider works.
    I basicly just copied the line so all variables are the same, then just changed the code variable.
    What is the deal with the back slider file path? Do can you only define one of these per skin page? I only have one.
    Any other ideas.
  1. Single click mode?
    By aoLhaTer in forum Road Runner
    Last Post: 01-15-2006, 11:49 PM
  2. Drop-down menus don't work? Read this!
    By gnomad in forum Announcements
    Last Post: 10-14-2005, 02:15 PM
  3. Quickest Way to Move Files
    By KingsDude in forum Newbie
    Last Post: 03-15-2005, 01:00 AM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
