Page 1 of 16 1234567891011 ... LastLast
Results 1 to 10 of 152
Thread: RR 2-19-06.. Extras & Fixes..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 2-19-06.. Extras & Fixes..
    In this Version:
    * Added Phoco Improvements by 'Robby_BMW'
    * Added support for mouse/touchscreen gestures
    * Added List Scroll Bar (Slider) Support
    * Added support for "WEBURL" to load predefined URLs
    * Added commands to set list view format on-the-fly
    * Added commands to Restart Sirius/XM
    * Added Gps Signal Slider support
    * Improved speed of Loading/Creating large playlists
    * Fixed issue with Manual Built-in Gamma
    * Fixed issue with gamma day/night values not reading from .skin file (when present)
    * Fixed issue with Master Volume & Balance not being read propperly on some cards/drivers
    * Fixed issue with "HIDECONTROLS" on Video Player
    * Fixed issue with Pink Transparency when resizing skins
    * Fixed issue definitions of static labels with comma
    Notes:
    -Gestures can be configured in gestures.ini -- instructions inside. You can test/tweak gestures with the tool included. This feature is ON by default, you can turn it off with this line in RR.INI: usegestures=false
    -New commands/definitions are described in Skin Commands.txt
    Version 2-19-06 has this changed from 2-18:
    -Added Robby_BMW Phoco improvements
    -Fixed issue with 'error 55' on first load
    -Fixed issue with dayskin/nightskin command switch
    If you'd like to see how Gestures work, check those two videos (XVID required):
    Alphabet Gestures
    Command Gestures
    Thanks for the support -- as always,
    Guino.
    Ride Runner RR's Myspace
    Raw Wave lostreception's Avatar
    NY
    gestures!!!
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    NY
    im getting runtime error 55 file already open
    win 2k all service packs
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Just made a few touch ups to prevent that problem.. just an issue with contributions merged with the main sources.
    FLAC djmickyg's Avatar
    Feb 2004
    nice work
    Newbie Smokemaximus's Avatar
    Dec 2005
    TX
    hmm finally got auto gamma working. Now with the update I get runtime error 91. object variable or with block variable not set? WTF? Gamma dont work now grrrr. 3 hours to get it working.. Guino you must die now!!!! LOL edit this is while i try and switch from within the skin to day or night gamma.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This gamma thing got a bit hectic on the last version, the values on general.ini were being ignored on the prev. version, now they're being used (at least when the gamma is set to MANUAL)..
    Please tell me your gamma settings so I can test this. You may need to either remove or place your gamma settings in general.ini
    Dec 2005
    TX
    Quote Originally Posted by guino
    Not sure what your needing. Im using the latest gammacontrol, and using it with KUO's skin. I had it set up to boot with rr at start-up. Now If I try and manually change to a night skin or day skin it gives me the error and rr disapears along with my taskbar. Oh my general ini's are set to false.
    May 2005
    Does it includes the new Phoco features made by Robby BMW?
    Better PHOCO integration in RR
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    Yeah! Another release of my favorite frontend!!
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
  1. RR 06-21-05 ... Improvements and Fixes..
    By guino in forum Road Runner
    Last Post: 06-28-2005, 12:35 PM
  2. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  3. RR 03-02-05... Fixes only..
    Last Post: 03-07-2005, 02:18 PM
  4. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
  5. RR 2-20-05 ... Bug Fixes ...
    Last Post: 03-01-2005, 02:27 AM
