Results 1 to 5 of 5
Thread: Keypad navigation and focus
    FLAC djmickyg's Avatar
    Feb 2004
    ive done a little search but nothing aswered my question
    when using the keypad to navigate,
    when a program is embeded it will stele the focus from RR making the shortcut keys nolonger work
    is there a way to make RR check and regain focus
    or a line to add to the shortcut key to make it get focus??
    thanks mick
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is the intended functionality -- exactly so you can use the keyboard on your embedded application. A simple ALT-TAB can do the trick. Now your "issue" is probably because you don't have a FULL keyboard available and my problem is that the same way that you're asking for RR to steal focus away, I'll have other people asking for RR NOT to steal the focus away. All I can recommend is for you to assign a shortcut key on the embeded application or use a hot-key application to try and assign a key globally for the simple purpose of simulating ALT-TAB for instance.
    Ride Runner RR's Myspace
    Feb 2004
    is there any way to make the RR commndsa global so they work regardless of it being focused or not?
    May 2005
    Vienna, VA
    Use Girder.
    Feb 2004
    Quote Originally Posted by guino
    is there anyways u could put this in as a setting, something like
    keepfocus=true|flase ??
    i will have a go at girder too..
    thanks
  1. Onscreen keyboard
    By gti in forum Map Monkey
    Last Post: 06-14-2008, 11:00 PM
  2. Replies: 1
    Last Post: 09-20-2005, 08:14 AM
  3. StevieG's Ford Focus Car PC
    By stevieg in forum Show off your project
    Last Post: 08-19-2005, 11:13 AM
  4. Im pretty sure im retarded
    By netboy in forum PowerVoice
    Last Post: 11-02-2004, 08:27 PM
