Results 1 to 10 of 12
Thread: Hi embbeding apps driving me mad can some one tell me what i
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    Hi i am trying to embbed apps into my skin but its driving me mad and my head keeps going
    before i do it all in my own skin i was testing it in one of the other skins i have, i have looked at the two FAQ about this but thats made me more confused
    OK i have managed to get my TV software to open when I click the TV button, but it opens out of the tv.skin and thats what i am trying to inbed it in
    can some one see what i may have done wrong
    This is the tv buttone code
    Code:
    B14,643,415,145,110,"LOAD;tv.SKIN;tv;C:\Program Files\DTV\DVB-T USB 2.0\DVB-Tplayer.exe;TV 2.1","tv"
    and this is the tv.skin file
    MEDIACAR Skin
    MEDIACAR TV Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B19,26,505,64,84,"UP","Up"
    B18,102,505,64,84,"DOWN","Down
    B06,176,505,64,84,"PLAY","Play"
    B08,328,505,64,84,"NEXT","Next/FF"
    B05,251,505,64,84,"PREV","Prev/FW"
    B17,404,505,64,84,"MUTE","Mute"
    B02,477,505,64,84,"VOL-","Volume-"
    B01,551,505,64,84,"VOL+","Volume+"
    B04,626,505,64,85,"ZOOM","Zoom"
    B12,722,505,74,94,"EXIT","Exit"
    /, A, x, y, w, h, color;RGB
    A01,230,60,551,420,000,000,000
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,13,463,191,27,13,463,191,27,H,01,"POINTER2.gif ",013,"MASTER","Master"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L03,23,72,180,35,255,245,000,18,"Tahoma:B","TRACKN AME","Track name"
    L07,138,440,65,20,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
    L09,25,5,175,25,055,055,055,18,"Arial Narrow:B","TIME","Time"
    L10,25,30,175,25,055,055,055,18,"Arial Narrow:B","DATE","Date"
    L11,655,5,50,25,055,055,055,18,"Arial Narrow:B","=Car:",""
    L12,655,30,50,25,055,055,055,18,"Arial Narrow:B","=Out:",""
    L13,710,5,65,25,000,125,000,18,"Arial Narrow:B","TEMP1",""
    L14,710,30,65,25,000,125,000,18,"Arial Narrow:B","TEMP2",""
    /, I, x, y, w, h, Code;INDICATORCODES
    I05,435,538,20,25,"MUTE:b"
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,23,115,180,300,255,255,255,000,000,000,255,245 ,000,226,244,123,000,000,000,TRUE,17,"ARIAL NARROW:B"
    END
    NOTE: I havent done anything to the tv.skin file as according to this i dont have to
    but when i was looking at this one it says about doing a ini file, but this is for the launch folder
    hope some one can help me with this and i am sorry if this gets asked alot i have searched but didnt get any look
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I thought the TV skin was a reserved skin, ie reserved for the TV cards that Guino has programmed for.
    ie How do I setup TV / Camera Support ?
    try calling the skin tv1.skin
    and make sure you have the correct window name "TV 2.1"
    Jul 2005
    uk
    im just trying this now thank you
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    did it work?
    Live mp3Car Facebook Chat
    Jul 2005
    uk
    ok i have tryed it useing this code
    "LOAD;tv1.SKIN;VidioRenderer ActiveMovie Window;C:\Program Files\DTV\DVB-T USB 2.0\DVB-Tplayer.exe;VidioRenderer ActiveMovie Window","VidioRenderer ActiveMovie Window"
    i also tryed some other was like with just the class of the window and not the text but its still not embbeding, i tryed it with another program and that worked.
    I think it could be because there are like two screens for the program one being the controls, is there any way i could make a new skin so that they both get embbeded in the skin, if so would i have to have the program called to serten sections of that skin or would i just do it like i have been doing
    sorry for all the questions this is my first time doing something like this i have been just running all the programs in a different window and it looked a mess, so i thought it was time i sorted it
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    First seems that your class name is misspelled "ViioRenderer..."
    Second, If you're trying to embed based on a classname, you need a "!" in front of the classname as in "...exe;!VideoRenderer ..."
    Third, you should refrain from using the tv.skin for anything other than with the winamp TV plugin. I have no idea what adverse effects that could cause. (I see you changed it to tv1.skin)
    If you post the information on the window you found with winspector spy it would help us help you figure out the issue since we don't have the software you're trying to embed. Please provide both the window title/name and the classname you obtained.
    Ride Runner RR's Myspace
    Jul 2005
    uk
    Hi mate i didnt relize i did a spelling mistake i have alterd that but no luck
    this is what i get in winspector
    Main window frame
    class name = Afx:400000:b:10011:0:b0295
    text = DVB-Tplayer
    window view
    Class name = VideoRenderer
    text = ActiveMovie Window
    Control panal
    class name = #32770
    text = DVB-Tplayer
    i have attached a image of the program if that helps any, i will not be using the tv.SKIN for my car pc i will be useing another style but thats only if i can sort this out.
    I am going to try and make all the prgram go in the same skin but its looking like i cant so fare
    Jul 2005
    uk
    I have just been doing some reading and have noticed that there isnt a way to embed more than one app in the same skin yet, but if is there anyway that 3 small skins can get ran in a way that looks like one skin so that 3 apps can be added
    Jul 2005
    uk
    Hi mate thank you i looked at that it says its to be used with iGuidance LOL sorry to be dumb on this but you wouldnt have any info on what iGuidance is
  1. Drunk Driving Speech
    By Cheekz185 in forum Off Topic
    Last Post: 06-24-2008, 02:40 PM
  2. Driving in Italy - An American View
    By Bugbyte in forum Off Topic
    Last Post: 11-14-2006, 06:50 PM
  3. Please help! - this is driving me mad!
    By dan_t in forum Newbie
    Last Post: 03-09-2005, 11:08 AM
  4. External Apps
    By netsuo in forum NeoCar Media Center
    Last Post: 12-20-2004, 02:38 PM
  5. External Apps - Having Problems
    By RobIles in forum Media Engine
    Last Post: 07-02-2004, 01:38 PM
