Results 1 to 10 of 10
Thread: audio browser slow....very high memory usage
    Oct 2003
    Copenhagen, Denmark
    I have been having the same problems as a few other ppl with my RR becoming quite slow, both at load of the initial applications, gps, audio browser, audio player, but primarily the browser. What i recently figured out was that when i press the key i defined for down/up in a list the cpu jumps to 100% for the duration of the delay, and also the memory allocated to RR.exe jumps from around 14megs to 31megs !!! is that not something very strange ? i disabled any kind of id3 tags any formatting of the listing....still no go. any suggestions ?
    Not doing carpc anymore
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Using the latest RR version, correct? (I think 2/19/06). What other software is running at the same time?
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Oct 2003
    Copenhagen, Denmark
    yup, just upgraded it today, still the same issue. I have the same problem on my other homepc 1,4Ghz t-bird. which is quite a bit more powerfull but only slightly faster than my epia800. I have only RR running on the epia, even without anything else like gps running it is still the same, however it does not get any slower if i start a browser/gps at the same time.
    Oct 2003
    Copenhagen, Denmark
    OK, i tried something interesting now......my skin is BrushMetal, and in the skin file in question (audio_browser.skin) i found this in the bottom :
    /, (R) Movie Information
    /, FORE BACK
    /, x y w h r g b r g b pt font
    R01,000,000,001,001,255,255,255,051,084,103,15,"Ar ial:B"
    Now i can't find any reference to that in the skin commands file.......so i removed it and it does not lag nearly as much, i can step 10-12 items down the list and then like 0,5 secs lag, no biggie. Seems to have fixed the problem.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    do you have any large text files in your music folders ?
    Ride Runner RR's Myspace
    Oct 2003
    Copenhagen, Denmark
    let me check.....i did have some text files of around 2 kilobytes in some dirs. Could that be the reason for the list scroll lag ? like i said, i cant find the RXX skin command, so i have no clue what it does
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Rxx... is a definition for Album TEXT art. The original alpine skins had it, and so did the original MC skin. This is only in RR for compatibility reasons as it seems to be a very unpopular feature. I believe I just forgot to include that definition in Skin Commands.txt
    Oct 2003
    Copenhagen, Denmark
    ok, i just disabled that definition in the skin...works like a charm now. i only have lag on the initial listing and starting audio_browser/audio_player...but no big deal
    Constant Bitrate doublet's Avatar
    Aug 2005
    OKC, Oklahoma
    Quote Originally Posted by _dopehead_
    can you tell me exactly what you did? i'm having the same problems. sorry i'm really new to RR.
    Oct 2003
    Copenhagen, Denmark
    Well, go to the folder where the skin you are using is located. find audio_browser.skin, open it and find a line that starts with R and put a /, in front of it. Then try you browselist again.
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. High density memory compatibility
    By Lurieh in forum General Hardware Discussion
    Last Post: 02-17-2006, 11:34 AM
  3. designing audio system
    By 1DeepG in forum Newbie
    Last Post: 06-29-2005, 09:48 PM
  4. High cpu usage when audio is muted.
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-23-2005, 04:51 PM
