Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: For them who want a flash boot before RR here is how
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    OK this is for a Flash file to start before RR.
    I did this is Flash MXPro 7.0, here is how
    1) open a new flash document (for the one i did one layer is only needed)
    2) on the layer click on the first frame then in actions add this script
    Code:
    instanceName.onLoad
       fscommand ("fullscreen", true);
       Mouse.hide("true");
    3) I did mine at 30 frames (its up to you how many frames you want) now click on frame 30 then right click and insert keyframe, then add this to the action
    Code:
    fscommand ("exec", "start.bat")
    fscommand ("QUIT")
    stop();
    4) OK that is the actions done now you can add another layer and do all your graphics there if you like, i will leave that bit to you .
    5) OK save the file to some folder do this by file>save as>filename.fla (this is so you can edit it later i called mine start.fla)
    6) Now that you have done that do this file>publish settings>Windows Projector>ok
    then file>publish (this will make a start.exe flash file we will use that later)
    Now that is done we have to make a .bat file as you may have noticed i placed the file name in the flash script up there any how this is what you need to do
    1) open note pad and place this code in
    Code:
    @echo off
    START c:\Program" "Files\Road" "Runner\rr.exe
    EXIT
    the path is set to c:\Program Files\Road Runner\rr.exe the " " are there as windows dos dosnt like spaces
    2) save the file as this start.bat (make sure it dosnt save as start.bat.txt) to the same place as the start.fla and the start.exe (just for now)
    OK thats it nearly done just need to place all the files in the correct places note i have done this thinking that your root path for RR is the same as most others so take all this in lol
    1) Make a folder in c:\Program Files\Road Runner\ called fscommand it has to be called fscommand else it will not work
    2) now place this files in the root paths
    c:\Program Files\Road Runner\fscommand\start.bat
    c:\Program Files\Road Runner\start.exe (note flash file that is .exe)
    4) thats it test it by clicking the start.exe flash file
    Now as some of you know you can boot strate into this by following this FAQ
    Hope this is ok i have attached a zip file that has my start.fla file in so you can look or even use
    Attached Files Attached Files
    Jul 2005
    uk
    This is a question i just got asked (i place this here just incase others are having this problem)
    Quote Originally Posted by avalanche2006
    madkad,
    great job but i was testing your files and i got the start.exe created and when you double click it it starts the animation and when the animation is done thats it. I created the start.bat file and when you double click it it
    start Road Runner fine, but when i double click the start.exe and the animation finishes it doesnt load the start.bat.
    i wasnt sure what you meant by this--
    how do you add this to the path?
    thanks
    Hi please try and ask the questions in the tut so others can see cheers
    OK open the Program Files and go to your Road Runner folder (this is the path), place the start.exe (this is the flash file) in the Road Runner folder.
    Then in the same Road Runner folder place your fscommand folder that contains the start.bat file, thats it these should be the paths to each file
    you can check these by doing this
    start > Run > and type in the paths like these (one at a time)
    starting with
    if this is in the correct path it should run, then if the fscommand folder is in the correct path it shoul all work, if it dosnt work type in this
    if the file isnt found then you need to place the fscommand folder in the correct path.
    Hope this helps
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    Jul 2005
    uk
    lol was it that bad my tut
    if any one wants this i am willing to make it them if they tell me what there after in style
    Feb 2006
    Thumbs up
    Hey dude, nice tutorial.
    Would you be able to do me a Ford Laser one for my upcoming carpc? I'm up to selecting front-ends now and have pretty much settled on RR with the MC2.0 skin
    Cheers in advance!
    Jul 2005
    uk
    Hi thank you yes i can lol but you will have to tell me more on what you are after when you say Ford Laser how do you meen also what colors you are after etc etc
    Jul 2005
    uk
    OK i have made these for Ti-ejtsch. OK here they are note that they will be full screen so the white sides you will not see
    version 1
    version 2
    hope there ok
    Oct 2004
    NY
    I have flash but don't have a clue how to actually use it.....
    I have a pontiac logo with some text & I would love to have a flash load, maybe have the logo spin into place, or the graphic & the text come from both sides & merge in the middle or ???
    any clue as to where I can find a simple tutoral on seting something like this up in flash?
    thank you very much for your work here
    Jul 2005
    uk
    Quote Originally Posted by turbocad6
    Hmm i dont no of a such tut that would show you how to do that but if you like i can do it for you and then give you the files so you can see how i did it if you want me to please give me the images you have and that
    May 2005
    Germany
    @madkad
    GREAT!!!
    Version 1 is the one I like!. You understood what I wrote down in my readme, and that with my terrible english :-)
    Is it possible to make the flash a bit slower, only a bit. The path I wrote in the readme, is the one to my frontend, you´re right.
    Thanks a lot for your really great work
    Greetings from Germany
    Ti-ejtsch
    Low Bitrate McFreak's Avatar
    Mar 2005
    McKinney, TX
    Have you thought of making a flash file that pulls its data from an .xml config? That way you could have all the animations setup and people jsut change the XML to what they want it to read? you could also call the logo externally as well.
    CarPC v2: Infiniti G35 Coupe 6MT, DW Housing, IBM R40, GPS, XM, StreetDeck
  1. Replies: 10
    Last Post: 04-17-2006, 05:23 PM
  2. sending keystrokes to flash?
    By Nitrov8 in forum Road Runner
    Last Post: 04-07-2006, 12:51 AM
  3. Replies: 1
    Last Post: 09-14-2005, 10:37 PM
  4. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 05:05 AM
  5. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 06:03 PM
