Results 1 to 8 of 8
Thread: Different shortcuts on different screens
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    Hey all,
    is it possible to have different shortcuts for one key on different screens?
    e.g. when i press "enter" on the audio player it toggles between play, pause and when i press "enter" in the gps skin it brings up the menu?
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    I don't know about toggling on the same screen (unless you use girder or something), but you can have different functions for different screens. I think the keytbl.ini file has the documentation for it...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    associate your keys to new commands on keytbl.ini, then define your new commands on a per-screen basis in exectbl.ini..
    Keytbl.ini:
    37,"COMMAND1"
    ExecTBL.ini:
    "COMMAND1","PLAY",audio_player.skin
    "COMMAND1","STOP",menu.skin
    Ride Runner RR's Myspace
    FLAC djmickyg's Avatar
    Feb 2004
    WHAT! no way
    i have been tring to do this for so long..
    Feb 2004
    with this way do u have to put in every skin u use to make it work the short cut work in all skins?
    does that make sence?
    May 2005
    Dresden / Germany
    Great stuff....!!!!
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    WOW - this changes everything...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by djmickyg
    You can specify commands to execute on ALL or on specified screens.. it's all the job of ExecTBL.INI:
    "COMMAND1","PLAY",menu.skin
    "COMMAND1","STOP",audio_player.skin
    "COMMAND1","MUTE"
    Above, COMMAND1 will execute MUTE in any screen except for menu.skin and audio_player.skin -- where it has other functions. This will work as long as your "default" command is the last, I mean, is defined after (below) the lines that define it on a per-screen basis.
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 11:45 AM
  2. Difference between VGA and Non VGA Screens??
    By sould in forum LCD/Display
    Last Post: 11-25-2005, 10:09 PM
  3. Connecting multiple screens to 1 Carputer
    By Nesvik in forum LCD/Display
    Last Post: 09-14-2005, 04:57 AM
  4. Video playback on multiple screens
    By sweetlikealemon in forum LCD/Display
    Last Post: 07-05-2005, 04:53 AM
