Results 1 to 5 of 5
Thread: RR & Carweb Integration
    Jan 2006
    When I integrate Carweb Mozilla 1.1.3 ro RoadRunner using Road Runner Configurator I get Below Error.
    Run-time Error '53'
    File not Found.
    I have Car web in RR.ini file
    browsertype=1
    browserpath=C:\Program Files\CarwebMozilla\Carweb-mozilla.exe
    I changed browsertype to 0 not effect.
    I can use Carweb as a stand alone app without any problems..
    (I am using Winxp SP2 full installation)
    Any help is much appreciated.
    Ben
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The only two web browsers currently supported by the "WEB" featuere are IE and FireFox. IF you want to use another browser, you should set it up as an embbeded application (either through the APPS screen or using the methods described in the FAQs, that is via the LOAD command).
    Ride Runner RR's Myspace
    Mar 2005
    UK
    try changing to a dos formated directory.. eg. no spaces. c:\webmozila\
    Raw Wave
    Jun 2004
    On the beach
    Also remove the - from the filename, that might help.
    Jan 2006
    Carweb Integration to RR **Fixed**
    Had a lot of help from Carweb guy. Thank you Peter.
    I downloaded Carweb-Mozilla 1.3
    Steps:
    1) Go to your RR skin folder and rename menu.skin file to something else as a backup.
    My menu.skin file is in C:\Program Files\Road Runner\skins\BAV2
    2) Open backedup skin.menu file with wordpad and change below line
    B07,348,335,102,75,"WEB",""
    to
    B07,348,335,102,75,"LOAD;rrweb.skin;Carweb;C:\Program Files\Carweb\Carweb.exe;Carweb"
    Note: your path to Carweb.exe may be diffrent to mine
    3) save this file as menu.skin in your RR skin folder
    4) copy attached rrweb.skin file to C:\Program Files\Road Runner\skins\your skin folder
    5) Click on the WEB Button to open Carweb and Check OSK and all other buttons.
    6) Done.
    Attached Files Attached Files
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 06:05 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
