Results 1 to 8 of 8
Thread: Audio gatway issues with Road Runner and Phoco
    Sep 2005
    UK
    I apriciate this is more of a RR and bluetooth issue than a phoco one but I was hoping you could help me to understand what is going on exactly.
    The situation is this. I have a SE V800, registered Phoco 1.6, Widcomm 5 drivers and road runner.
    If I use phoco by itself, everything is fine, on incomming and outgoing calls the audio gateway service connects and the service works as expected. The windows bluetooth config does tell me that the comm connection ends before the audio gateway service starts but I am not sure I trust this, it is certainly not shown in the phoco log. Anyway this all works fine and I can see the below line in the log file
    26/02/2006 15:39:01 Callers photo not found!
    26/02/2006 15:39:01 >ATD01256470489;
    26/02/2006 15:39:01 Bluetooth headset on device 'V800' connected!
    26/02/2006 15:39:02 <
    OK
    26/02/2006 15:39:11 >AT+CPAS
    26/02/2006 15:39:11 <
    +CPAS: 3
    OK
    26/02/2006 15:39:11 >AT+CSQ;+CBC
    +CSQ: 12,99
    +CBC: 0,46
    OK
    26/02/2006 15:39:30 >AT+CHUP
    26/02/2006 15:39:30 <
    OK
    26/02/2006 15:39:30 Bluetooth headset on device 'V800' disconnected!
    26/02/2006 15:39:31 >AT+CPAS
    26/02/2006 15:39:31 <
    +CPAS: 0
    OK
    However if I use phoco through road runner in the remote no design mode the audio gateway doesn't connect on outgoing or incomming calls. I can so no evidence of this in the trace
    OK
    26/02/2006 15:57:22 RemoteCommand: <PhoneControl.NET><Dial number="01256470489"/></PhoneControl.NET>
    26/02/2006 15:57:22 Callers photo not found!
    26/02/2006 15:57:22 >ATD01256470489;
    26/02/2006 15:57:22 <
    OK
    26/02/2006 15:57:28 >AT+CPAS
    26/02/2006 15:57:28 <
    +CPAS: 3
    OK
    26/02/2006 15:57:28 >AT+CSQ;+CBC
    +CSQ: 6,99
    +CBC: 0,45
    OK
    26/02/2006 15:57:48 >AT+CPAS
    26/02/2006 15:57:48 <
    +CPAS: 4
    OK
    26/02/2006 15:57:48 >AT+CSQ;+CBC
    26/02/2006 15:57:49 <
    +CSQ: 6,99
    +CBC: 0,46
    OK
    26/02/2006 15:57:50 RemoteCommand: <PhoneControl.NET><Hangup/></PhoneControl.NET>
    26/02/2006 15:57:50 >AT+CHUP
    26/02/2006 15:57:50 <
    OK
    So my question is obviously, why is this happening? Is it a lack of code on the RR side or the Phoco side? Also for my own piece of mind is the serial port disconnecting to allow the audio gateway or are both services running as they should on the SE phone.
    Many Thanks
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Add this line in your rr.ini file "connecthsp=true" to see if it will be helpful
    Sep 2005
    UK
    Thanks for the idea robbie but that didn't seem to work. I haven't looked at the log files after making this change but it definatly doesn't turn the audio gateway on.
    Sep 2005
    UK
    Right, I have added the line you suggested and run rr in debug mode. I started by dialling a number a couple of time and then by calling my mobile, both with no luck.
    http://www.cruizer.plus.com/debug.txt
    http://www.cruizer.plus.com/debugnofd.txt
    Unfortunatly I ran the debug with freedrive running so there is alot of location rubbish in there. Debug.txt is the raw debug and debugnofd.txt is the same file but I have deleted all the fd lines to make it easier to read.
    I can't see any command that would turn the audio gateway on? Is there a command I can add to the accept call button to enable the audio gateway?
    I also double checked and the audiogateway and it doesn't seem to come on when I use phoco through rr but it does if I use phoco directly.
    Many Thanks
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I think a command need to be added to tell phoco to release the COM port in order for another BT connection to be made (using Phoco's SDK).. or so I heard.. this is the same with trying to dial the internet via BT when using Phoco... my condolences for all of you that own phones with crappy BT support.. not sure when I can look into it, specially since my phone doesn't have this limitation, so I could never be sure it's working when testing it... Making this change does affect the software in the way that you MUST end the call through the computer (since phoco won't be connected to the phone and wont be able to alert RR that the call has ended using the phone)...
    Ride Runner RR's Myspace
    Sep 2005
    UK
    Ah, but I dont have a phone with crappy bt support. My phone is able to maintain both serial port and audio gateway services at the same time, the problem is the audio gateway service doesn't start when going through rr. I am also chasing zorro to see if this is a limitation with the remotenodeisgn feature.
    Sep 2005
    UK
    Robby, Zorro has suggested I talk to you about this issue. It seems you are the newly apointed Phoco RR integrator.
    OK, so the ini seting you suggested doesn't seem to do anything, is there a command I can run to actually connect the audiogatway, I can then just include this on the recieve button?
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Cruizer, are you using your PC mic to speak to the caller?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  1. iDrive for Road Runner - Originally by BTBE
    By Enforcer in forum RR Skins No Longer Supported
    Last Post: 05-02-2007, 08:07 PM
  2. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  3. phoco w road runner embeded
    By liquid_smoke in forum PhoneControl
    Last Post: 07-19-2005, 10:45 PM
  4. Phone control in Road Runner
    By RoyN in forum Road Runner
    Last Post: 05-09-2005, 01:04 PM
  5. phone icon on road runner brush metal honda skin?
    By mick0uziel in forum Road Runner
    Last Post: 03-27-2005, 04:32 AM
