Results 1 to 10 of 12
Thread: I'm having a hibernation issue
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    When I resume from hibernation the volume control no longer works. Its stuck at what ever volume I had it at last. The percentage values change in RR but the actual volume doesn't. To fix it, I have to close RR and open it again and all is back to normal. I'm using an Audigy 2 NX with the newest drivers and firmware. Anybody else have this problem?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Let me guess... that's a USB sound card you got ?
    Ride Runner RR's Myspace
    Oct 2004
    yep. Is that normal for all usb devices? I know my gps used to have issues till I used Xport. The windows volume control works ok though so I thought it was something in the prog. I'll try frodo and see if I have the same issue.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    guino's Avatar
    Nov 2004
    Toronto, Canada
    no, that's not *NORMAL* for anything.. it's just the crap you have to put up with using USB stuff. I can *try* to add something to close/reopen the mixer at hibernate/resume but I have no way of testing it without a USB sound card, so I can't guarantee anything.
    Oct 2004
    That would be great. I'll test it for you but it's a pretty common sound card from what I've read on the forum. I find it hard to believe that I'm the only one with this issue. Is there anyone else out there that can verify that it is a software issue and not a motherboard issue before GUIDO wastes any time on this?
    On another topic, thank you so much for the updates and neverending fixes to small bugs. It's very much appreciated. A lot of other front ends wouldn't give the time of day for issues like these. Thanks for your hard work.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    Now that I have the volume in RR control wave, I realized that when I hiberbate with RR open the wave volume jumps to 100% on resume and RR still will not control it till I close it and reopen. On resume RR still indicates the volume prior to hibernation eventhough it is now at 100%. I hoped the new release 3-6-6 would fix it but it did not.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Try to go into/out of hibernation with other media player (winamp, wmp ... ) to see if the same problem.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2006
    I'm italian and sorry for my bad english.
    I have the same problem when I resume hibernation.
    I have the Audigy NX USB.
    Another problem when resume hibernation is: the system check the Audigy after 10sec + or - ....if I have winamp played a songs, when resume hibernation there is an error that tell me no found audio card...so I click ok and restart winamp, and now is ok.
    Whitj normal reboot there is all ok.
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    There is no fix for this. I just got rid of my nx because of the same problem. The problem is when you disconnect the power to the nx during hibernation. When you boot up the computer the nx doesn't resume right away. It takes a few seconds after winamp is already trying to use it. I was thinking about leaving power connected to the device, but I'm worry about power drain. Go with PCI if possible.
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
    Oct 2005
    why not just use S3 standby instead of hibernation?
  1. 5 minutes to complete hibernation? WTF?
    By DRWeside in forum General Hardware Discussion
    Last Post: 03-12-2006, 10:36 PM
  2. Hibernation and Lilliput Weird Issue
    By wsudu in forum General MP3Car Discussion
    Last Post: 11-15-2005, 08:26 AM
  3. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 02:16 AM
  4. Hibernation Issue!!
    By autopilot747 in forum Newbie
    Last Post: 03-23-2005, 10:34 PM
  5. Not coming out of Hibernation (Intermittently)
    By Jailer in forum General MP3Car Discussion
    Last Post: 10-23-2004, 09:11 PM
