You'll have to figure out how to send commands from RR to GIRDER. The RR GML file is currently designed to do just the OPPOSITE (from Girder to RR).
Girder has a little program called event.exe that lets you execute events in girder from the command line. I just did it here to test, basically you have to use the RUN command in RR to run this event.exe with the event name to execute in girder. You may need to enable the internet event client plugin and you'll need to associate the events with the commands you want to execute.. a tip for you is that the event names are case sensitive so you should be sure to match up the casing of the eventstring and the parameter for event.exe.
LinkBack URL
About LinkBacks
