Results 1 to 3 of 3
Thread: red dot problem?
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    red dot problem?
    hi -whenever i click and drag the mouse, i get a lovely trail of red dots, which will change go to the next song when i drag forward, and go back when i drag it backwards. its great and all but when i want to up or down the volume, i change the song. can i turn this off or what am i sposed to do?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    You will be able to set non gesture sections on the next update of rr, but you will need to add these yourself to your current skin that you use. You can disable the gestures by adding the following line to your rr.ini
    this will stop the reddot for now :-)
    Jan 2005
    Phoenix, AZ
    Quote Originally Posted by CdRsKuLL
    <off color>
    If only women had this setting
    </off color>
    1998 BMW M3
    Mods: Staggered SSR Competition wheels : M Roadster Short Shifter : JTD Aluminum Underpanel : Koni Adjustable SAs : Eibach Pro-kit springs : European clear corners and side markers : Hardwired V1 automatic door and radar detector
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 08:57 PM
  2. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 11:17 AM
  3. Computer Building Problem
    By 0l33l in forum General Hardware Discussion
    Last Post: 05-09-2005, 01:52 AM
  4. Slightly Different ITPS Problem
    By FRP in forum Power Supplies
    Last Post: 10-16-2004, 12:04 PM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 08:19 PM
