Again with RRConfig -- look for the option that says "map master volume to" .. that will allow you to select a line other than master to control.
If you just want to change the line of a specific slider, then you just have to open the .skin file and change the slider code for the slider. All possible slider codes are listed in skin commands.txt
LinkBack URL
About LinkBacks
