Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: RR Spiking CPU - Not Flash
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Ok. I build a new carputer and had it running flawlessly in house for a couple weeks. It was blazing fast and RR was working sweet.. Yesterday I install it in truck and now RR is acting just like the FAQ says "High CPU Load, Buttons Fail to Respond, Flash Issues/Spins too Fast ?".
    Now, like I said.. Everything was working fine in house. These are the things I changed since in car:
    * Custom Resolution of 800x480 via Nvidia onboard video
    * Using Xport
    * Installed USB GPS
    * Added USB Wifi card
    That's pretty much it.. Reading the FAQ I definately don't think it's flash related being that it worked fine for weeks. Quino also mentions the VIA 4-in-1 update but I don't have a VIA board..
    I haven't tested changing the resolution yet but I sure hope it's not because that's one of the reasons I got the board I did so I can run 800x480. Anyone have any thoughts?
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Oct 2003
    Poland, OH
    Yea, I'll do that. I was just hoping someone would say "yea, x happened to me and I had to do x". I just hope I don't have to go back to 800x600.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should change it back for TESTING.. then you'll know if that's causing you any problem.. if you didn't change any major settings with RR or did any updates on the software, then this shouldn't happen... I'd just change the res. not run xport and unplug the GPS/Wifi Card... if that doesn't change the CPU load, then there's probably something else you did causing the issue (something you don't remember doing).
    If your CPU is "spiking" say every so many seconds, then make sure you have those lines in RR.INI (set the port to appropriate values if you use xm/sirius):
    vcomport=0
    tcomport=0
    xmport=0
    srport=0
    Ride Runner RR's Myspace
    Oct 2003
    Poland, OH
    Well good thing is it's not the resolution. I changed it and it still happened. I did forget to add that I did add some lines manually to the rr.ini to try and get the gps speedo to work.
    I added:
    mappointport=xxxx
    gpsport=xxxx
    to the end of my rr.ini. Maybe that jacked it up? Should those port numbers be the same?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    wouldnt affect it either way. Though if youre not using mappoint you can remove that line.
    Live mp3Car Facebook Chat
    Oct 2003
    Poland, OH
    Quote Originally Posted by guino
    vcomport=0
    tcomport=0
    xmport=0
    srport=0
    What is vcomport and tcomport?
    EDIT - Nevermind.. Search RR Readme.txt
    vcomport = Voltmeter COM port
    tcomport = Temperature sensor COM port. Set 0 to disable.
    Oct 2003
    Poland, OH
    Quote Originally Posted by Sonicxtacy02
    I thought if you wanted to use the speedo you had to have both lines? I may have read that wrong though..
    Woodbridge, VA
    Blog Entries
    55
    which speedo? The one from MC2.0? Thats from freedrive. Unless i'm mistaking you dont need to have both in your .ini in fact i run mappoint and iguidance and still only have gpsport.
    Jul 2004
    For what it's worth, I had issues with slow flash and unresponsive buttons when I had the XMPORT configured and my XMD1000 wasn't plugged in. Plugging in the XM receiver or setting the XMPORT=0 when the receiver wasn't connected fixed things for me.
    Carputer installed!!!
    Nlited XP+Minlogon, EpiaM10k, 512mb, Seagate 40 gig 2.5" HD, FM Dlink usb radio, DWL122 USB Wifi, XMD1000 tuner, PT5071 6 amp regulator, Xenarc 700TSV, and 1 ikea key box.
  1. Replies: 24
    Last Post: 03-03-2006, 01:36 PM
  2. What is normal CPU usage for RR?
    By Jstarko0329 in forum Road Runner
    Last Post: 12-01-2005, 02:40 PM
  3. Can this be done in RR and flash
    By tolisn in forum Road Runner
    Last Post: 06-16-2005, 02:57 PM
  4. Can RR set frame of flash movie?
    By Arathranar in forum Road Runner
    Last Post: 06-09-2005, 10:57 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
