Results 1 to 4 of 4
Thread: Reset switchbutton and switchlable
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I think a command to reset switchbutton and switchlable to the beginning or a way to switch to a particular position would be a good idea.
    B,,,“1>>2>>3>>4>>5>>6>>7>>8”
    Maybe
    “Switchbutton;3;4” – to switch button 3 to the 4th position
    “Switchbutton;2;1” – to switch button 2 to the 1st position
    “Switchlabel;5;5” – to switch label 5 to the 5th position
    That way you could set up buttons for deferent modes from button from previous skins
    B,,,”Exit||switchbutton;2;3||Switchlable;6;4| switchlabel;10;3”
    B,,,Audio>>audioGPS>>xm>>xmGPS>>radio>>radioGPS>>a pps>>appsGPS and so on
    2001 S10 ZR2
    Chucks Skin - to old
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the problem is that RR doesn't keep track of the "position" of the button so to speak, it just rotates the codes without worrying about them. I could create a "setbutton" command to completely set the code of a button, but it wouldn't work to set the code to switchable commands. but this would work:
    B1,,...,"A"
    B2,,....,"SETBUTTON;1;B||SWITCHBUTTON;2>>SETBUTTON ;1;A||SWITCHBUTTON;2"
    Then you could make a reset command/button in the same fashion..
    Ride Runner RR's Myspace
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    That would be a lot better then what I suggested
    2001 S10 ZR2
    guino's Avatar
    Nov 2004
    Toronto, Canada
    will do.
