Results 1 to 8 of 8
Thread: Hotkeys and skins
    Feb 2006
    Hotkeys and skins
    I am evaluationg front ends and skins. I loaded up a skin in RR. CRX blue I think it was. I found that the naviagtion buttons to select tracks didn't have keyboard commands nor did the arrow keys work. I thought maybe this was controled via a skin but after looking through the skinning tutorial I don't think so. I am hoping to setup an front end that is fully navagable without the use of a mouse. Is this a pipe dream?
    Qs:
    Are button hot keys (keyboard commands) set via a skin?
    If not, does one have to modify the source RR project to implement them?
    Was there a keyboard command there and I just didn't know what it was?
    Any help you can offer is apreciated. Thanks in advance.
    May 2005
    Vienna, VA
    It's all defined in KeyTBL.ini. Yes, you define the actions.
    Feb 2006
    Ahh. I see it. Cool. So those are global setting reguardless of what skin I use? Sweet.
    May 2005
    Vienna, VA
    Yes, they're global. While you're at it, check out ExecTBL.ini, too. You can define custom commands in there.
    Aug 2004
    Germany
    I don't quite get how it works. I put this line in my exectlb.ini file:
    "a","UP",audio_player.skin
    Basically, I want RoadRunner to execute the command "UP", if I press "a" and the "audio_player.skin" is open. Doesn't work though. Do I need a keytbl.ini ? AFAIK the keytbl.ini is just required when I want to setup global keys for RoadRunner, correct ?
    Aug 2004
    Germany
    Hm. Just read, that I have to use keycodes. Still have a problem though:
    When I put the line:
    222,"UP"
    in the keytbl.ini of RoadRunner it works as it should. But when I put the line:
    222,"UP",audio_player.skin
    in the exectbl.ini in the skin directory nothing happens. Any Ideas ?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    keytbl.ini and exectbl.ini have different purposes.
    Keytbl.ini is short for keyboard Table, ie it is designed to allocate hotkeys
    exectbl.ini is short for executable table and is designed the set up commands and command paths.
    Aug 2004
    Germany
    Ok, works now as it should. Thanks for clearing that up .
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
