Results 1 to 10 of 15
Thread: Navigon NCK 4 in RR
    Newbie WaterLift's Avatar
    Feb 2006
    Belgium/Aalst
    Lightbulb Navigon NCK 4 in RR
    Hi guys,
    Very nice frontend
    Is there any way to use the external GPS soft Navigon 4 NCK, because when I try setting it up in RR it doesn't load and it would be nice to have it in RR because of the OSK which I need to input the address.
    Here is my rr.ini extract:
    showid3browse=false
    gpsmode=2
    gpsport=3
    mapmonkeypath=C:\Program Files\NAVIGON GmbH\NCK 4.0 Notebook\NCK.exe
    gpspath=C:\Program Files\NAVIGON GmbH\NCK 4.0 Notebook\NCK.exe
    gpsname=NAVIGON GmbH
    exitmode=0
    showicons=true
    showextensions=true
    titlesafter=-
    listfollowssong=true
    I tried different methods but none will load the navi soft
    Please help
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Read the how to embed FAQ.. follow the process to verify if the window title is correct.. you may be runnint the application on the background and not seeing it.. you should also set gpsport=0 during your tests, so that RR doesn't prevent your GPS app from using it. if it still doesn't load, make a .bat file like:
    C:\NCK.bat
    with this inside:
    @echo off
    c:
    cd \Program Files\NAVIGON GmbH\NCK 4.0 Notebook\
    NCK.EXE
    Then set the gpspath to:
    gpspath=c:\nck.bat
    Ride Runner RR's Myspace
    Feb 2006
    Belgium/Aalst
    Thanks mate , gonna check the FAQ asap. I did but probably on the wrong keywords
    When I get the specs for the ini file I'll post them here for future reference.
    I'm of to and with some luck I'll be when it works.
    Cya
    PS: I love those wacky emoticons
    Feb 2006
    Belgium/Aalst
    Unhappy
    Well I tried with Winspector but the problem is that navigon starts in full screen mode and doesn't have a titlebar
    Also tried it with the bat file but no joy.
    This is what I can get from the window list and properties in Winspector.
    Properties for window 0x00190154
    Item Value
    Class Name Afx:400000:b:10011:6:e201fb
    Text NCK 4.0
    Rectangle 0, 0, 800, 600
    Size 800, 600
    Client Rectangle 0, 0, 800, 600
    Client Size 800, 600
    Styles WS_OVERLAPPED
    WS_VISIBLE
    WS_CLIPSIBLINGS
    0x00049152
    StylesEx WS_EX_LEFT
    WS_EX_LTRREADING
    WS_EX_RIGHTSCROLLBAR
    ID 0
    Properties
    Class specific none
    Owner EXE C:\Program Files\NAVIGON GmbH\NCK 4.0 Notebook\NCK.exe
    rr.ini:
    gpsmode=2
    gpsport=0
    gpspath=C:\NCK.bat
    gpsname=!Afx:400000:b:10011:6:e201fb
    exitmode=0
    showicons=true
    showextensions=true
    Am I forgetting something? I checked the taskmanager after clicking GPS in rr but no mention of NCK in there, the bat file works ok by itself.
    VIA Epia M10K
    1 Gig RAM
    200 Gigs HD 3.5" ATA
    M2-ATX
    CTF-700 7" TFT TS
    Haicom GPS Sirf III
    Morex Case
    Car2PC
    WiFi-g
    BMW--SarCP
    ▬▬▬▬▬▬▬▬▬▬ H/W
    ▬▬▬▬▬▬▬▬▬▬ S/W
    ▬▬▬▬▬▬▬▬▬▬ Dash
    ▬▬▬▬▬▬▬▬▬▬ Install
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    U won't get NCK embedded in RR because it has no static border...
    The only thing u can try is to add the following code to the top of your nck.ini:
    [Dimension]
    Width=800
    Height=550
    OffsetX=0
    OffsetY=0
    That will start NCK in 800x550 in the top left corner. U can optimise these values for your own belongings
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you should listen to dbassix.. but just for your information, when a class name is all numbers like you posted, normally those numbers CHANGE from time to time everytime you run the application.. so you may want to look for that and see which numbers change and don't include that in the setting..
    Feb 2006
    Belgium/Aalst
    I've been playing around with the class names but still no luck
    Even been trying integrate explorer and calc just to see rr would load it, but didn't work. Can someone see what I did wrong or give me an example to load a standard windows app in the gps window, so I can see the result in rr gps window?
    Here is my extract:
    gpsmode=2
    gpsport=0
    mapmonkeypath=
    gpspath=C:\WINDOWS\explorer.exe
    gpsname=!ExploreWClass
    exitmode=0
    showicons=true
    showextensions=true
    titlesafter=-
    Cheers
    VIA Epia M10K
    1 Gig RAM
    M2-ATX
    CTF-700 7" TFT TS
    Haicom GPS Sirf III
    Morex Case
    Car2PC
    WiFi-g
    BMW--SarCP
    ▬▬▬▬▬▬▬▬▬▬ H/W
    ▬▬▬▬▬▬▬▬▬▬ S/W
    ▬▬▬▬▬▬▬▬▬▬ Dash
    ▬▬▬▬▬▬▬▬▬▬ Install
    Feb 2006
    Belgium/Aalst
    Thumbs up
    I'll be damned, just tried with the BM skin and it loads Navigon perfectly Guess Simplistique is a bit buggy not rr
    Now just gotta find out how to put an OSK icon on the top bar in BM ;-)
    VIA Epia M10K
    1 Gig RAM
    M2-ATX
    CTF-700 7" TFT TS
    Haicom GPS Sirf III
    Morex Case
    Car2PC
    WiFi-g
    BMW--SarCP
    ▬▬▬▬▬▬▬▬▬▬ H/W
    ▬▬▬▬▬▬▬▬▬▬ S/W
    ▬▬▬▬▬▬▬▬▬▬ Dash
    ▬▬▬▬▬▬▬▬▬▬ Install
    Newbie getyours_2006's Avatar
    Jul 2006
    Netherlands
    I'm also trying to get navigon to work embedded with roadrunner. I've changed the the window name in navigon 4.0 and it runs but the navigon screen is to big for rr screen how can i fix this
    Forget it if fixed the window problem but how can I keep the audio control buttons in the windows
    See here the fx
    See here what I want
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    as you set follow string inside your nck.ini
    [Dimension]
    Width=800
    Height=525
    OffsetX=0
    OffsetY=0
    your nck application is showing in a box like 800x525, starting on position 0,0
  1. Navigon NCK 4 on Wine
    By sarasini in forum Linux
    Last Post: 04-22-2006, 01:51 PM
  2. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 06:05 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
