Results 1 to 6 of 6
Thread: IG, Works on it's on but not in RR (No GPS)
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    For some odd reason I can launch Iguidance on it's own and the GPS works fine. When I launch it inside RR it keeps saying GPS not found. I go in and tell it the correct com port and it still says GPS not found. The rr.ini has the correct com port as well.
    Any ideas??
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Jun 2004
    Central California
    I had the same problem last nite. I had to change the GPS port on RR to 0 for iGuidance to recognize the GPS once embedded into RR.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    Oct 2003
    Poland, OH
    Thanks. I'll try that.
    May 2005
    Vienna, VA
    No, this is the problem. The COM port in RR.ini is for RR to display things like speed on its own. That will cause a conflict with iGuidance. Put a blank value in there.
    If you still want RR to connect to the COM port, use a port splitter like XPort (search other forums) then use one for RR, one for iGuidance.
    Oct 2003
    Poland, OH
    Thanks b8bboi!
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    I'm using a USB GPS Reciever (LT-20) w/ my RR and anytime I hit GPS it any skin other than the Brushed Metal skin it crashes and burns. I can use it as a standalone w/ no problem. Boy and I frustrated...
  1. Replies: 11
    Last Post: 01-31-2006, 04:37 AM
  2. OK a viz that works fullscreen with RR
    By accentsound in forum Road Runner
    Last Post: 01-09-2006, 11:45 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. Audio crash BSOD 0x000000F4, gps, etc works fine, help?
    By Urinemachine in forum Software & Software Development
    Last Post: 04-21-2005, 10:16 PM
  5. Replies: 9
    Last Post: 12-08-2004, 09:48 AM
