Results 1 to 8 of 8
Thread: skin browser art not showing
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I am modifying a skin browser page, and for some reason, the skin art will not diaplay anymore. In the properties, there is only size and location coordinates. I don't see why it stopped working. Here is the skin's code:
    Code:
    MEDIACAR Skin
    MEDIACAR mmi Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,6,0,160,50,"LOAD;multimedia.skin","Multimedia"
    B02,635,0,160,50,"GPS","Navigation"
    B03,000,450,150,050,"LOAD;misc.skin","Misc"
    B04,650,450,150,050,"LOAD;system.skin","Misc"
    B05,000,525,100,075,"VOL-","Volume down"
    B06,100,525,100,075,"VOL+","Volume up"
    B07,200,525,100,075,"MUTE","Mute"
    B08,300,525,100,075,"PREV","Prev"
    B09,400,525,100,075,"PLAY","Play"
    B10,500,525,100,075,"NEXT","Next"
    B11,700,525,100,075,"CANCEL","Exit"
    B,356,392,100,40,"SELECT","Select"
    B,700,250,100,200,"DOWN","Down"
    B,700,050,100,200,"UP","Up"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,223,08,200,030,255,128,0,15,"Arial Black","TIME","Time"
    L02,435,08,200,030,255,0,0,15,"Arial Black","DATE","Date"
    L03,185,460,70,30,255,0,0,15,"Arial Black","VOLUME","Volume"
    L04,279,460,350,30,255,0,0,15,"Arial Black","TRACKNAME","Title"
    /, J, x, y, w, h
    J01,230,113,355,255
    END
    Why isn't it working? any help would be appreciated.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    does the skin browser work in any other skin ? cause your .skin file seems fine.
    Ride Runner RR's Myspace
    Sep 2003
    Tampa, Florida
    The skin browser works with the Brushed metal skin, but when I try to use the skin browser in my skin, thewre are no images. If I click
    "select" roadrunner disappears, and a gray square appears at the top left of my screen with a album cover in it. I have to close RR using the windows task manager.
    WORKLOG
    Webpage
    guino's Avatar
    Nov 2004
    Toronto, Canada
    if your file is really defined as you posted, then the only explanation is that your skin file is not called "skin_browser.skin" -- but in this case, RR would not load the list of skins correctly and it would not display/select the skins propperly either.
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    If it still doesn't work try adding a "S - Launch List" to the skin with RRSkineditor. I remember having the same problem and that took care of it.
    Example:
    Code:
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,370,521,300,27,255,245,000,000,000,000,000,000,000,255,255,255,TRUE,18,"MS Reference Sans Serif:B"
    Sep 2003
    Tampa, Florida
    DiNASTY, that worked! thanks for the tip. the skin I'm working on doesn't lend itself to a list well, but I was able to massage it into there. Guino- is it a requirement that there be a list for it to dislay properly?
    WORKLOG
    Webpage
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by Snootch
    I think what you want is like browse by art, but I think that only works in the audio browser. Atleast I couldn't get it to work in the video browser.
    It's the cake having/eating thing.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    browse by art should work with anything, even the skin browser, but you'd have to define the SD line by hand to point to the right path..
    It is necessary to have a list entry in the skin browser, yes, but it doesn't have to be in a visible location .. you can simply define it starting at 850,0 if you don't want it to show.
  1. [Release] SKINbedder V3 - Preview
    By RPM_VR4 in forum SkinBedder
    Last Post: 08-16-2008, 09:22 PM
  2. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  3. Replies: 36
    Last Post: 12-13-2005, 07:38 AM
  4. new skin 'Blue'
    By CdRsKuLL in forum RR Skins
    Last Post: 09-25-2005, 05:48 PM
  5. YASQ: Skin Paths not correct
    By Viscouse in forum Road Runner
    Last Post: 09-24-2005, 08:14 AM
