Results 1 to 8 of 8
Thread: RR, FD and window issue
    Feb 2005
    I have a little problem with integrating FD.
    I designed an address skin from into RR to FD
    I call this skin with:
    "LOAD;ADDRESS.SKIN;address;FreeDrive.exe;FreeDrive ||SendMsg;FreeDrive;address","address"
    the problem is that I start FD within RR normally the the window with the cities and the streets didn't appears, as you can see at the image below.
    If I start FD Previous to RR (at windows starting), and after that, I start RR, the the window appears OK. This involve that I must have FD allways started to work.
    Do you know what the problem is?
    thanks and Regards
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    I had the same problem, but it is fixed in 1.0
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    Feb 2005
    I have this problem with 1.0 and also with 1.0 preview update 1
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I assume you are actually loading FD on BEFORE you load your screen ? otherwise you have to place the entire path to FD on your load command cause just FreeDrive.exe won't cut it.
    Ride Runner RR's Myspace
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Same problem here, as well in 1.0 preview and 1.0 preview update 1. I think it is an FD issue, because FD version 0.9 didn't have this problem.
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
    Raw Wave
    Jun 2004
    On the beach
    Remember that its possible to do an FD address skin and embed RR commands into it with 1.0. I know its only a workaround.
    Will see if we can do anything about the skinning issues.
    Feb 2005
    Ye I load FD as external_gps skin all works except only this.
    I know that I can do the skin into FD, the black window with the osk is FD, but doing this way I have more space for the window.
    thanks and regards
    SMKFree liquid_smoke's Avatar
    Aug 2003
    didnt one of the FD releases change the window title name? Not sure about this, just kind of remember something did this. FYI i dont have this problem.
    beer replenishment fund
    mp3car live search
  1. What's the best RR skin to embed FD in?
    By srcstc in forum FreeDrive
    Last Post: 03-08-2006, 06:03 PM
  2. Sending RR commands to RR inside FD.......
    By Spaghetti in forum FreeDrive
    Last Post: 12-24-2005, 07:49 AM
  3. Office2003 & freedrive
    By ShawJohn in forum FreeDrive
    Last Post: 06-23-2005, 07:46 AM
  4. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 06:19 PM
