Results 1 to 8 of 8
Thread: RR and Phoco some issues
    Feb 2005
    Hello,
    I have some issues regarding to the phoco integration:
    1.- when I receive a Call the in call window, display unknow for a while and then changes to the correct name from the phonebook. But at the windows call (missed calls, received calls,...) the entries remain with the unknow name.
    2.- SMS. at the sms inbox, all the sms messages appears with the same name (at the sms.xml file also is saved with that same name), when I display the detail for every message the name is the same bad name, but the number is the correct one.
    3.- SMS. the sms outbox, send and archived are allways empty.
    4. the calls list (missed calls, incoming calls, dialed calls and all calls) seems that only have the entries of when the phone is connected to phoco, is it possible the pick these lists from the phone allways?
    5.- there is a phoco.ini file to translate some info, but didn't works, allways appears that names is english. what must I do to work correctly?
    thanks for your comments
    regards
    Low Bitrate GolfChick22's Avatar
    Nov 2005
    Cheshire, UK
    i have the same issue as number 2 so would be interested in an anwer to this also, altho it does make a certain person seem obsessed with me :-D
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Sorry for the delay in answering, but I am just come back from my vacations.
    Quote Originally Posted by kocke
    This is a PhoCo's problem, I've noticed that sometime, on incomig call, there is a delay in recognizing the caller's numbers.
    This is another PhoCo's problem. You can see it analyzing the PhoCo's log.
    This is normal, the sms outbox store the messages for a little time until they don't are effectively sent and the archived box store only the sms saved by the command "SAVE".
    RR do it, but only with the phones that support it.
    Have you uncomented all the line that you want to translate?
    f.e.
    unknown_caller=Sconosciuto
    incoming_call=Chiamata da:
    in_call=In conversazione con:
    outgoing_call=Sto ciamando:
    intPhoneBook=Rubrica interna
    phonePhoneBook=Rubrica telefono
    simPhoneBook=Rubrica SIM
    allCalls=Tutte le chiamate
    inCalls=Chiamate entranti
    outCalls=Chiamate uscenti
    missedCalls=Chiamate perse
    SMSin=SMS ricevuti
    SMSout=SMS in uscita
    SMSsent=SMS inviati
    SMSarchiv=SMS archiviati
    Low Bitrate DonkeyBoy's Avatar
    Mar 2005
    Stockport UK
    Am interested with item 2 too. am currently running phoneco on own and using a button to switch from rr to phoneco
    it sems to be a phone co issue. !!???
    let me know if anyone comes up with a solution!
    VIA EPIA M10000 LVDS 1Ghz Motherboard,
    256Ram,80Gig,
    Lilliput 7" In Dash Touchscreen
    Panasonic Slimline Slot-in Cdrw/dvd Player,
    USB Gps Reciever,
    Belkin Bluetooth dongle
    Belkin USB wifi
    Carnetix CNX-P1290 60W Power Regulator
    Feb 2005
    Hello and thanks
    Quote Originally Posted by Robby BMW
    From 1.-
    Yes but, at the windows list of incoming calls the entrie is saved as unknown
    From 2.-
    I can't see at my log, How can see that?
    From 3.-
    But I have messages at the archived SMS and at the sent SMS, and that lists are empty at RR
    From 4.-
    My phone supports it, With phoco standalone I can see the Dialed, Missed and Incoming calls
    From 5.-
    f.e.
    ok, I uncomment and it works
    Thnaks and Regards
    Aug 2005
    Italy
    Hi kocke, I'm sorry for the short answers that I've give you in the previous post, but I was very busy.
    1 - Yes but, at the windows list of incoming calls the entrie is saved as unknown
    This happens because RR saves the incoming calls immediately. I have got some ideas on how to solve this issue, but this will be on the futures release.
    2 - I can't see at my log, How can see that?
    What I want to say is that for some strange reason, sometime, PhoCo gives back the list of SMS receipts with the same sender's name. I don't know if this is only in remote control or also in stand alone mode.
    If you try to connect to PhoCo with a telnet program, like "Hyper Terminal", and play with the remote commands, you can see what I mean to say.
    How you can see in this thread RR is not the only frontend that get this issue, however I think that I will be able to by-pass this problem in the futures release of RR.
    I think do you refer at the Archived Box and the Sent Box of your phone, but unfortunately PhoCo doesn't support this. It only can read the Incoming Box of the cell phone, so RR can store in these boxes only the messages managed by itself.
    This is a strange issue. I need to make some test to check it.
    Feb 2005
    Thanks for your responses
    and congratulations for your collaboration to this fabulous front end (also for Guino!!)
    Regards
    Aug 2005
    Italy
    This preview release of RR would have to solve some issues of the current phoco integration.
  1. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  2. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  3. Phoco not working in RR Win 2000, help...
    By couteau in forum Road Runner
    Last Post: 09-06-2005, 10:04 PM
  4. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 10:32 AM
  5. RR 04-19-05.. Improved Phoco..
    By guino in forum Road Runner
    Last Post: 04-20-2005, 11:38 PM
