no, it don't work![]()
And yes photo.skin load, but nothing append. CPU utilisation don't move, it don't even try to open the exe !!!
This command should work:
"LOAD;PHOTO.SKIN;Photos;C:\8\acdsee8.exe;ACDSe e 8 Photo Manager"
Now, when you click the button I assume that at least the photo.skin file is loaded and shows up ? Please try it and let us know.
Ride Runner RR's Myspace
do you have a shortcut to the exe? (that works)
if so right click, select properties and copy and paste the target here
Yes I have one, here's the target:
target: C:\8\acdsee.exe
start in: C:\8
I had also try to launch the shortcut instead of the app itselft but it didn't work.
Originally Posted by mr_sarge
then why in all your attempts to run it, posted above. have you stuck an 8 on the end?
ie acdsee8.exe instead of the above acdsee.exe.
that's why the exe don't run![]()
oups, sorry, the 8 must be there![]()
In my last attempt, I have remove the 8 in the exe to try with a shorter name "a.exe" but forget to put it back when i have rename the exe to "acdsee8.exe"
I don't work![]()
someone has acdsee to test it?
just the demo should be ok !! just to know If it's the programm itself or i'm really stupid and I should leave my job of computer technician !!
just tried.
very strange.
I can get it to bed if I run the exe seperately, either before or after I start RR.
However it won't run from RR.
I can copy and paste the path and exe into the start-->run command and it works fine.
woohoo it's not me !!
but this don't solve my problem!!
did you try launching from a .bat file ?
