read skin commands.txt.. there's no need to use BOTH the load and the run command at the same time.. the load command can do everything at once.. now, if the snes emulator worked for you, then most likely it should work for acdsee too, but you need to make sure you have the right window title in the command -- read the "how to embed" faq to know how to get that information (in fact, this should be pretty much all you need to get this to work).
LinkBack URL
About LinkBacks
