Results 1 to 5 of 5
Thread: Passing commands to MM through RR
    Apr 2005
    Belgium
    Problem passing commands to MM through RR
    Weird : using exec.exe, I can send simple commands such as NEXT or GPS which work perfectly, but when I send MM commands such as MM;View_3D (from the Skin Commands.txt file), it doesn't seem to react...
    Can anybody confirm ?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try adding your command to ExecTBL.INI and calling exec on the new simplified command..
    "MM3D","MM;View_3D"
    Then:
    Exec.exe MM3D
    My guess is that some characters used in RR commands may not be propperly passed as parameters to exec.exe.. you may also try:
    exec.exe "||MM;View_3D||"
    since the OS normally preserve what's between the quotes before executing the application, it should also work.
    Ride Runner RR's Myspace
    Apr 2005
    Belgium
    Quote Originally Posted by guino
    "MM3D","MM;View_3D"
    Then:
    Exec.exe MM3D
    You may also try:
    No, strangely, none of the above work. I tried to determine if the problem was due to special chars as you suggest, but the following works :
    exec.exe SEEKTO;01:15
    I also tried other MM commands such as MM:ZoomIn, but no result either, so it looks like it's linked to MM.
    Can someone confirm this ? Is there a way to debug the communication between RR and MM ?
    Thanks for your help.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Do those commands work if you put on a .SKIN file in RR ? If not, then you should look closely at the settings you need to set in MM to make this work.. this is in the GPS FAQ.
    Apr 2005
    Belgium
    As always, you're right... the default MM settings were still there - no interaction - while I thought it would have worked "out of the box"
    Maybe you could add a word in Skin Commands.ini such as :
    See Map Monkey's SDK Manual for list of commands and RR's GPS FAQ on how to activate this feature in Map Monkey
    That could save you from a few newbie questions like mine
    Thanks a thousand times. I confirm : RRRules and so does its author
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  2. MM doesn't send complete Street info to RR?
    By davidovi in forum MM Bugs
    Last Post: 11-17-2005, 05:08 PM
  3. MM Commands for displaying data from MM in RR
    By mcflurri in forum Road Runner
    Last Post: 08-04-2005, 02:20 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Creating RR Skin For MM
    By studly_steve007 in forum Map Monkey
    Last Post: 04-14-2005, 02:20 PM
