Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: RR 03-06-06 AVS problem
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have tested this in multiple machines (3-6-06) with the AVS on the latest winamp and with 2.95 and had no issues.. honestly there's nothing that changed from previous versions in what it regards to starting the visualization plugin.. the only thing done was to add support for the "FULLAVS" command which is not used unless you execute that command.
    Ride Runner RR's Myspace
  2. #12
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by guino
    Indeed also I have tested in other 3 PC home the new version, and all ok.
    But if used the same version, and identical skin /configuration in my car, crash the System.
    I don't use the "FULLAVS" command.
    If I load the preceding version of RR, identical settings/skin, in my car and home PC, then all ok.
    Mystery!
    Mauri
  3. #13
    guino's Avatar
    Nov 2004
    Toronto, Canada
    what winamp/avs plugin version are you using in the car ? Have you tried a different version ?
  4. #14
    FLAC mauri's Avatar
    Jan 2004
    Winamp v. 2.9.2.0
    The AVS plugin it's "Elvis_Real3d_Sentinel"
    No. I don't have change version of Winamp in my car , the same version and AVS plugins I use in my home PC and work all ok.
    Mauri
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    please try winamp 2.95 (and 5.xx) to see if it also crashes -- you can always re-install 2.92 if it doesn't work right.
  6. #16
    FLAC mauri's Avatar
    Jan 2004
    Tested with the v.2.95 and v.5.21 new,but tha same, in my carPC crash the System...
    For this moment I use the old version of RR unfortunately for the problem of the AVS that doesn't work....
    Mauri
  7. #17
    Newbie Mr_PHOENIX's Avatar
    Feb 2006
    Map monkey in new RR problem
    Hii..
    I have a problem with new RR. when i drag the map in map monkey, the pointer change to a red bubble and if i release it, the music change to the next song ?
    IF, i use previous RR, i have no problem. i can drag it.
    is it a bug of new RR?
    Thank you
  8. #18
    guino's Avatar
    Nov 2004
    Toronto, Canada
  9. #19
    Feb 2006
    Thanks for fast responce.........
  1. Problem whit cdrip whit rr
    By manung in forum Road Runner
    Last Post: 10-26-2009, 07:27 AM
  2. Problem with RR and 640x480 skins.
    By bosse in forum RR Skins
    Last Post: 09-19-2005, 03:59 PM
  3. Strange problem whit RR and Girder... HELP
    By slimmegane in forum Road Runner
    Last Post: 07-06-2005, 07:40 AM
  4. problem updating RR?
    By Rs! in forum Road Runner
    Last Post: 03-16-2005, 12:21 PM
  5. RR 2-27-05 Audio Browser problem
    By Curly_cat in forum RR Bug Tracker
    Last Post: 03-02-2005, 01:40 PM
