Deja vu???
With the new version of RR, if I launch the AVS, RR crash.
But in the previous version,same settings,all ok....
In my home PC work all ok,only in carPC this problem...![]()
Mauri
does it crash immediately after you start the AVS ? cause I have not changed anything with that.
Ride Runner RR's Myspace
one thing i noticed (not specific to this release though) is the fact that when i have a vis open (normally i just use the AVS studio windowed) my CPU utilization bumbs up to 100% solid.
Is this normal? I am running a p4 2.8 ITX board
I'm not even able to get the vis to run windowed. Full screen only.
Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
maybe you dont have enought horsepower
doubt that's it. it was working in an earlier version.
it's just a pain if i accidentally hit the button. i have to pull over, open the trunk and hit the escape key. i finally just commented the button out of the ini file. it would be cool to have though.
im running rr on a 1ghz system with 512mb, and i can run a vis without it crashing so i doubt its lack of power... however when i do run avs cpu hits 100% steady as well.
They agree, in my Epia M10000 and 512MB, CPU with AVS work to 100%...Originally Posted by tasteItheIvalue
The crash of the System with AVS in this new version of RR perhaps depend on a bug?![]()
Mauri
