Results 1 to 10 of 10
Thread: Newb question about Copilot and RR
    May 2005
    Sup ppl
    I did some research and I have found out that my gps program doesn't work well with any front ends so I just run RR and Copilot at the same time and alt-tab between the two. My question is...is there anyway I can have RR mute the music or just lower the sound when gps announcements are played by Copilot?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    copilot is one of the few awkward applications that (as far as I know) won't integrate well with anything.. that includes both embedding and volume control.. supposedly the best application for nav. but the worst for integration/mixed tasks.
    Ride Runner RR's Myspace
    May 2005
    Thank you for the response.
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    CoPilot and Road Runner is a no go...
    Hey,
    Thought I might add to the conversation, as I have both CoPliot (here after referred to as CP) installed with Road Runner, and I am trying to make them work together.
    I think the short answer is that they don't...and alt-tab switching doesn't work very well, in my opinion. This is because to switch from CP to RR, you just need to hit alt-tab once, but to switch from RR to CP, you need to hit it twice for some reason. This makes it difficult to set up any sort of non-keyboard controller to switch between the two programs smoothly.
    Any other questions, let me know, and I'll try to test them out for ya...
    Gregory
    guino's Avatar
    Nov 2004
    Toronto, Canada
    what about if instead of Alt-Tab you minimize RR using a button ? would that not display CP with a simple click ? I'd assume that the Alt-Tab would still work to show RR again.
    Dec 2005
    Dallas, Texas
    Yep...a minimize button would probably work well...I was just curious as to what determines whether programs take one or two ALT+TAB keypresses to both bring up and switch to another program. Is this something that the developer decides and implements?
    The reason I had hoped to use ALT+TAB to switch between RR and CP was because I could do it fairly simply with a Powermate through keypress emulation...however, now that I've looked around on the forums a bit, I see that there are other ways to accomplish the same goal.
    Thanks for your reply and help....
    Gregory
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Alt-Tab is a windows controlled function.. I don't think a software can "require" two Alt-Tabs or something like that.. most likely if you have to press Alt-Tab twice, is because you're alternating through another window of the same application (Copilot).
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by guino
    That makes perfect sense of course...maybe I should try doing a bit of thinking instead of so much typing next time.
    Gregory
    Newbie PoweruP's Avatar
    Apr 2005
    Australia
    Hi, i also use co pilot and have noticed it wont embedd into RR. We need some sort of simple overlay screen like how mediaengine or frodo does it, Co pilot worked fine with them rather than trying to embedd CP into the skin. I really like RR but that 1 prob sux
    Skyline R33 Gtst: Carputer: ViaM21200 Mini itx, 512DDR, 80gHDD, 7" Lilliput TS, 90w Opus,Win MediaCen Ed, (now running) ROADRUNNER!! as shell, CoPilot8, Microtech EMS, EpsxE, N64.
    Apr 2005
    Australia
    Guino any possibility of making the above happen? would be greatly appreciated by lots of people in Australia
