there are hard-coded label codes and there are dynamic label codes.. an example of a hardcoded is "DATE" -- directly from RR, independent of anything and was added directly to a list of supported label codes. Dynamic label codes are normally flexible to accept anything you throw at them.. so if MM later releases support for new information, you could start using it right away without any changes in RR .. (like "MM;NEWINFO")... there's also support in RR to allow setting labels from outside applications as well, so anybody that wants can build applications that show information directly in RR's skins (That's what FD does).. I believe there's already a code to pull out the heading from MM -- If not, the GPSXXXX tags from RR will work simply because RR reads the GPS info from MM already...
LinkBack URL
About LinkBacks
