1-Set your full screen mode to a different resolution than you run RR in, then click the right edge of the screen (ONCE) to close the vis directly.
2-You probably have some bad setting in place, also, this "hang" issue should have been fixed on the latest version even with a bad setting.
3-Again, this was fixed on the latest version.
4-Check your setting on RRConfig, if you're using the GPS Menu option, the SKIN must have the correct screen for it to work, or it won't do anything.. change the option or try the BMV2 skin to verify that it works.. this DOES depend on the skin you're using.
LinkBack URL
About LinkBacks
