Results 1 to 10 of 10
Thread: RR error message
    Jan 2006
    RR error message
    hello, RR was working earlier this morning, i uninstalled a different frontend (since like alot of us, download alot of them and test them and see if they like it but i decided on RR) and then i tried to run RR and i got this error message
    I get the same message for the config utility and the actual app. I uninstalled it and reinstalled it and i got the same message. I searched for the DLL file and it was located in the
    C:\WINDOWS\ServicePackFiles\i386 path
    so i copied it and pasted in the dir of RR and it still didnt work. what is it and what can i do to fix it? thanks
    Jan 2006
    thanks for ur quick reply, I tried doing what u told to me. This is what i put in the run command
    regsvr32 C:\Program Files\Road Runner MSVBM60.DLL
    and i got this message
    what does this mean? thanks again
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    if used correctly, enforcer's solution works..
    regsvr32 "C:\WINDOWS\ServicePackFiles\i386\MSVBM60.DLL"
    But this is in the how to install FAQ (Just download/install the VB runtime):
    How do I install Road Runner ?
    You're probably getting this error because you installed/uninstalled an application with a badly made install -- I say badly made because it is removing SHARED OS files used by other applications such as the MSVBM60.DLL
    Ride Runner RR's Myspace
    Jan 2006
    thanks for trying guys but i tried the new command with the ' \ ' and the that guido suggested
    and i get still get this
    im going to uninstall RR and install it using the binary way. thanks, hopefully that works
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's NOT all I suggested.. the FAQ clearly says :
    Requirements
    -At least a VGA screen
    -RAM & CPU Requirements vary according to the skin used
    -Visual Basic Runtime Files (if you get DLL/OCX errors, get it HERE )
    -Winamp (www.winamp.com) -- MUST NOT be a LITE version and you should use a CLASSIC skin.
    (All versions should work -- Winamp 2.9 is recommended for performance reasons)
    It's the bold part that you need to do, go in the FAQ, click on the HERE word, download and install the runtime files.
    Uninstalling/Reinstalling RR will most likely NOT fix your issue.
    Jan 2006
    yea, sorry, i know what u meant but i forgot to write it. sorry. I already downloaded the VB runtime files and its working fine now. thanks
    May 2005
    Vienna, VA
    seriously, people, read the FAQs and follow the steps there. It's not rocket science.
    Newbie sympul's Avatar
    Aug 2008
    I'm a retard. Took me almost an hour to finally read that I had to extract the VB program to a file and then run it from there.
    ... I blame it on the fact that it's 2:30 in the morning.
    Thanks Guino, everything is working great now.
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
